I don’t understand wiring, no voltage to coil, no spark!
The car is a 1973.5 911T. I dropped the engine out for a refreshing, put everything back how I found it. Or at least I think so. Seems I’m not getting any voltage reading on the coil, of course no spark. The engine cranks over. Put in a new coil. Even bought another electric board, still nothing. Any suggestions? I’m about to pull the engine out again in case I missed something.
no need to pull the engine for a simple electrical problem.
I think you forgot to plug in all connectors or something is not fully seated. |
ROW '78 911 Targa
You won’t see voltage at the coil on a CDI system.
Check your points are opening and closing properly. Search “Dwell “. Red wire plugged in Beside the CDI box?
If it has a CDI system, does the engine have the "green wire of death" from the distributor? That damn little wire cost me a $1000 tow across Pennsylvania for my '86 930. The replacement wire was $50.
Find Spoke's LED Products: www.spokeworksled.com |
ROW '78 911 Targa
No “green wire” until 1978 6 pin or earlier 8 pin turbos.
This post can be very helpful.
