New Lug nuts for black Fuchs
For what ever it is worth, if you are thinking of purchasing new black lug nuts for your Fuchs get the aftermarket kind, not the OEM version. I purchase both to compare and the aftermarket nuts are far superior...harder surface and don't scuff as the OEM ones do.
Guy Chiattello
82SC Black Coupe
Old 05-03-2003, 07:54 PM
mussberger's Avatar
where did you you buy?
1981 911SC Black metallic, no sunroof. Sold(damnit)2005 987Guards Red, Stuttgart build. Sold1978 911SC Bahama Blue, M491 look E class PCA race car.Sold with help from Pelican. Thanks! 2005 997 Black. Sold1988 930 Grand Prix White. Keeper. 2008 957 Basalt Black, Pneumatic suspension and PDCC.
Old 05-03-2003, 07:58 PM
Is there a difference in cost? Can the aftermarket ones handle the stresses of a 911 as well as the OEM lug nuts, or better?
Professor M. Schiller
Metro New York PCA
America is successful not because of unions, but despite them.
UNIONS DESTROY AMERICA
www.CapitalistInstitute.org
Old 05-03-2003, 08:03 PM
one of gods prototypes
bell's Avatar
i picked up a set of aluminum ones from our host.........my wheels haven't fallen off yet
Brought to you by Carl's Jr.
Old 05-03-2003, 08:42 PM
Purchased from our host. Cost is about the same.
Guy Chiattello
82SC Black Coupe
Old 05-03-2003, 09:13 PM
Harlan Chinn's Avatar
I've got a set from our host and they are much nicer than OEM
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 05-04-2003, 10:29 AM
buttjoint's Avatar
are the aftermarket ones alluminum
Old 05-04-2003, 12:32 PM
Yes, The after market ones are alluminum.
Guy Chiattello
82SC Coupe
Old 05-04-2003, 04:45 PM
Weird, what brand are Waynes nuts??
I am actually curious, but I couldn't resist...
Old 05-04-2003, 05:58 PM
They must be "generic nuts" The label on my box says "Aftermarket Alloy Lug Nut, Polished Each"
Harlan Chinn
Old 05-04-2003, 06:13 PM
I have had trouble with the aftermarket lug nuts. They go on without a problem, but when I remove them, they loosen with a terrible squeak, like they bind with the rims. Yes the torque is correct, yes they are slightly copper pasted. The original (old) lugs used right after do not do that. Must be the alloy is not the same.
Kind of freaks me when I think about broken lug nuts stuck on the wheel.
I solved my dilemma- back to steel lug nuts! Very "R Gruppe".
GeorgeK
Old 05-05-2003, 11:45 AM
apply some anti-seize on the threads
Harlan Chinn
Old 05-05-2003, 11:51 AM
Irrationally exuberant
ChrisBennet's Avatar
I have steel lug nuts. They are a bit rusty now. Anyone try POR-15 on steel nuts? I figureed I just paint the outside, not the threads or bearing surface.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-05-2003, 11:52 AM
Certified Pre-Owned
BGCarrera32's Avatar
Personally, I'd throw a dab of anti-seize right on the mating surface of the nut (nut to wheel). I've seen them stick there (probably the squeak you're hearing) and then snap off right at the shoulder on the socket surface...
Just my 2 cents...
-BG
'84 Carrera Coupe
Old 05-05-2003, 11:57 AM
They HAVE anti-seize. It's as if the alloy of the lugs reacts with the alloy of the rims. Back to back testing shows this seems due to the alloy itself (?)
That is rather academic, as I go with steel lugs when the new engine is in.
GeorgeK
Old 05-05-2003, 01:05 PM
