sources for 3" diameter velocity stack screens?
I could use a set to fit the Racehead Engineering ITB stacks that are 3" across. Rama has nothing. Rimmer Bros doesn't have the right sizes. I was referred by Al Kosmal to Pierce online, but they want $55 each. $330 seems a little steep for six bits of cut screen with rubber surrounds. Hopefully there is another option.
2018 911 Carrera coupe 1972 911T targa |
RETIRED
That's what they go for. Pegasus wants 59 each. Bend over Porsche tax. No kiss or reach around. You could probably source the rubber at Mc Masters and screens as well. Cut and snip.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Good thought. Then I might be able to layer the screen for a bit of extra filter effect, as some of the regular-diameter filters are made.
Check some bike shops online
I would rather be driving
motorcycle stack filters. Some are just as expensive. Some are cheaper.
I had UniFilters on my ITB stacks for a long time. Flowed great. oiled foam with internal springs to prevent collapse under airflow. Just slip on and tighten the collar.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
69 911T & 86 911 Carrera
Maybe look in the Volkswagen world?
America’s own fancy-shcmancy kitchen utensil company...
https://www.amazon.com/OXO-Good-Grips-3-Inch-Strainer/dp/B001713L84/ref=asc_df_B001713L84/?tag=hyprod-20&linkCode=df0&hvadid=167134584690&hvpos=&hvnetw=g&hvrand=455169078474736628&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028050&hvtargid=pla-274772305578&psc=1 And some Trim Lok or similar
Ass-engine Nazi slot car -- PJ O'Rourke |
Try PJ Motorsports. ( google them )
Will these work for your application? I used to run them on a vintage racer (non-Porsche).
Velocity Stack Filters https://www.cbperformance.com/product-p/6373.htm
Brian Miller - Scottsdale, AZ 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S |
Does anyone know if any of the filters mentioned in this thread will fit porsche PM0 50mm stacks
thanks. frank |
tea strainer
![]() 3 1/2" tea strainer, amazon 1" of bike inner tube
gary burch 71 911 |
