Getting ready to bleed my brakes, please critique my technique
It's been years since I did my own brake bleed but last time I did it, I remember it was quite straight forward. I wanted to run my procedure by some of knowledgeable folk on this forum.
I own a '88 911 3.2 and will be using a Motive Power Bleeder. 1. Suck out most of the fluid from the master cylinder. 2. Top up the master cylinder with fresh brake fluid. I always alternate between blue and gold fluid so that I know when the new fluid hits the bleed port. This is where I depart from the usual process for Motive bleeding. I don't fill the bleeder. I overfill the master cylinder instead. This is to keep the power bleeder clean and free of old fluid. 3. Pressurize the system to 10psi. 4. Starting from the passenger rear wheel, attach a clear hose to the bleed port, open the bleed port and bleed into a waste container. 5. Check the master cylinder and top up with more fluid if required. 6. Move on to next wheel. 7. Once finished bleeding all four wheels, I top up the master cylinder and close it up. 8. Open beer and pat myself on the back. From what I recall, I didn't remove the wheels to do this. I could access the port by reaching behind the wheel. Am I mis-remembering? Any critiques on my procedure? I think it's been at least 10 years since I've done this and my memory is not what it was. |
All good except you need to crimp the overflow line from the fluid reservoir. I pull mine off and add a small length of hose that is plugged at the end. Also, I remove the wheels just for better access. Good luck!
2000 Boxster S and 2016 Audi A6 |
Pressure brake bleeding..........
Coilerman, Your above procedure is OK but I would add these:
Do not forget to remove the plug from the drain tube. Tony |
cycling has-been
..good luck finding the blue fluid - discontinued about 6-7 years ago.
If you do manage to come up with a couple cans - check the date.
73 911T MFI, 76 912E, 77 Turbo Carrera |
The two color option is gone, so make sure to flush enough fluid so that everything is fresh. Don't use fluid that's been opened before. Humidity from the air can contaminate it.
Since you shouldn't be using fluid that's been sitting in the Power Bleeder, always empty it after you're done. Therefore, there is no reason not to put the fluid in the Power Bleeder? You do start with passenger rear, because it is the farthest from the master cylinder. Then driver rear, passenger front, driver front. You use a clear hose so that you can be checking for air bubbles. You want to flush until there aren't any bubbles. If the bleeder fitting is too loose, air bubbles can come in from the threads; not the fluid. Wipe a little grease around the threads to prevent the air from sneaking in. |
Senior Member
I have consistently had good luck just using gravity. Run a hose from the RR bleed nipple into a good sized container and simply open the bleed nipple. Take the cap off the reservoir. Keep checking and filling the reservoir, of course. When the fluid runs clear, move to the LR. Then the RF and the LF. Done.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
cycling has-been
That being said, you are probably okay. Are you sure about that 5 years?
Open the caliper bleed valve and allow fluid (and air) to exit into the hose. Lightly tap the rigid brake lines and caliper with a hammer to dislodge stubborn air bubbles. Oh, and no compressed air pressure necessary. Cannot rush the air bubbles unless pricey BF goes with it. Using this method, only 1 liter of BF is needed to fill the entire brake system - usually impossible with pressurized air. Sherwood |
toss that old brake fluid - cut corners on paint or fuzzy dice, not safety areas
the Motiv gets filled with air not fluid gravity works |
FWIW, back when they had the two colors, I measured the volume I used to complete a color change. The farthest cylinder completely changed color when I got about 160 ml.
Why is there a pickup tube in the Motiv container if it's only for air?
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs |
I prefer to keep the Motive unit dry.
Driver
If you use the Motive, also hook it up to the master cylinder before you start the process. Just to make sure there are no leaks in the system before you start putting brake fluid through. Though probably less of an issue in your situation if you're not filling the Motive with brake fluid, because even if there is a leak, it's not likely that brake fluid is going to be spraying about.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Everytime I use a Motive, I have to add some grease to the bleed nipple because air comes through the threads causing a million tiny bubbles.
That is weird since the motive is pressurizing the brake system snd should be pushing the fluid out the threads not drawing air in. I used to have this issue when I vacuum bled the brakes.
That is what I thought too, the physics didn't make sense when I was doing this to my Vantage so I figured I had a leak. The grease was the fix and the exact same thing happened on my sons S5.
Let's hope the grease was compatible with the brake system. Dielectric grease perhaps? Sherwood |
I am my 911's PO
I used to put some grease around the bleeders (the same grease used to rebuild the calipers).
1978 SC - original owner 1983 SC - D stock "rescue" track car DECEASED 2015 Cayenne Diesel (rear ended by distracted driver) 2017 Macan (happy wife...) 2016 Cayenne Turbo - tow vehicle and daily drive |
