HarryD's Avatar
Porsche refers to that part (#6 on post 22) as a bearing. The part number is 914-347-711-00 and Pelican lists it as $206.75 (ouch!). Try a boneyard.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-10-2008, 11:24 PM
nice doggie
Hetmann's Avatar
I used a 928 part when I did mine. Slipped right in and solved the problem.
Jerry
78 SC hotrod
02 Mini Cooper S
Old 05-15-2008, 10:54 PM
GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Has anyone come up with a part # for the Bushing, the C shaped part that the spring pushes against? Mine is missing and without it there is slack between the NEW upper Bearing I just installed and the HUB. What can I do? Is there a Fix?
Originally Posted by Phoenix View Post
I'm replacing the bulbs in all my instruments and figured while I had the wheel off, I'd look into my steering column play problem and install the "quick fix" sleeve I've had for ages.
This thread has been very helpful and as I now know, the "quick fix sleeve" does not work on our earlies (wish I knew that earlier).
After a few hours of searching, reading, comparing posts and general brain whacking, I think I may have hit on something.
Once the wheel is off, the column end floats freely in the space between the inside of the bearing ring. It is then held in place with the help of a small bushing and spring which, on my car, were stuck to the backside of the steering wheel. (see pic)
On my car the spring and bushing were installed with the bushing facing the steering wheel and the spring situated between the bushing and the bearing. (see pic)
I believe this is incorrect and is actually what's causing the play once the wheel is installed and tightened. After switching the spring and bushing so that the lip of the bushing sits up against the bearing (which seems to make sense) and the spring is between the steering wheel and the bushing, the play is gone and I have a rock solid wheel. see pic
Can anyone tell me if this is indeed correct or if I'm just setting myself up for a problem later on? It feels right but I can't be 100% sure.
Old 12-16-2009, 12:28 PM
whackit's Avatar
call any of the big used parts places... partsheaven, dc, etc. they should have the parts for around $50. that's what i did. just describe it and they will know what ur talking about
1971 911E 2.7RS interpretation -- Signal Orange baby!
Old 12-16-2009, 02:29 PM
Silberpfeile's Avatar
Your second picture is the "fix". I had the same problem. All gone now. Thanks for sharing!
Old 08-26-2011, 12:05 PM
