911 SC Partial Engine drop Tips please
Looking to partially drop the engine of a 911 SC to change the oil switch and breather hose.
Would like to remove as little as possible. Anyone have any tips or procedures. Thanks in advance. Using an ATV MC jack on casters to lower and stabilize the engine. |
ROW '78 911 Targa
Have you read this?
https://www.pelicanparts.com/techarticles/911_partial_engine_drop/911_partial_engine_drop.htm
Here's a tip, don't leave that ATV jack unattended overnight. More than one case here where owners came out in the morning and found there engine on the floor. Some ATV jacks have a safety stop.
Walt 82SC 3.0 81SC 3.6 |
DO NOT forget to undo the shift coupler! (In the the tunnel, under the plate, behind the front seats.)
Keyla,
Here is an old rennlist post from Walt Fricke ("The Professor")... 1) release the shift coupler by loosening the rear setscrew. the coupler is below the plate with 4 sheet metal screws you need to remove to get to it on top of the shift tunnel between where the rear passengers' feet would be if ever anyone rode back there. This is a precaution, and when you put it back it will be just as before. 2)Take loose the connector on the wire loom which connects the rear of the engine to the relay etc panel on the left rear of the engine bay. Also loosen the greasy and oily oil breather hose which connects the engine to the oil filler/dipstick assembly - you can do this at the filler area (the engine breather line you couldn't release from its other end if your life depended on it). And the hose which connects the air filter area of the air box to this oil filler area. By the way, if you overfill your oil tank, the overflow goes through this line into the air box, and then out a drain on the front (transmission) side of the engine right next to the oil cooler you suspect of leaking. Oil coming out of this drain will look a lot like oil coming out of a leak in the cooler, and is a likely culprit for a lot of dirty oily guck in that lower part of your engine's world. 3) Put your jack under the rear of the engine and jack it up until the rear tires are off the ground. Put jack stands under the rear using the ends of the torsion bars at the spring plates and lower the car until it is just about to rest on the jack stands completely. Remove the right rear tire (since you are getting at the oil cooler). 4) remove the two rear engine mount bolts over at the sides of the engine compartment. 5) watching all other lines, wires, and so on which connect the engine to the rest of the car, lower slowly. When anything looks like it is getting tight or is going to get tight, stop. Don't come down too far, you just want some reaching and looking room over the air box and fuel distributor area, and you will get a bit more of that when you remove the rubber boot connecting the throttle body to the fuel distributor. In your case you have already drained your oil and removed the oil line connecting the sump tank to the engine via the bottom of the oil cooler. It's been a while since I did this, so watch things closely. The engine scavange oil line to the external oil thermostat should have enough flex for this, but you may want to disconnect it also. And it isn't hard to disconnect the two fuel lines. The efficiency of this sort of tilt lowering comes in not having to remove the CV s and the sway bar and the tranny mount bolts and the heater hoses from the heat exchangers to the valves, and the accelerator rod . 6) as a precaution, put some sort of wood blocks under the engine at this point to back up your jack (I once had a jack slowly lower the engine/tranny assembly over night, even though I thought I had tightened the release mechanism). This will give you enough room to inspect the idiot light sender area and to replace the sender on general principles. If it is original it might indeed be leaking after 18 years. However, it is near the breather exit and that area seems always to have stray oil. Once you do this you will see that it is easy enough that if you are not losing much oil you might want to just clean things up some and replace the oil warning sender and put everything back in order and see if your leak has stopped. However, you should have enough clearance to get at the oil cooler cover bolts, and, when you get that off, the two top bolts which hold it on so you can remove it for inspection and pressure testing if it shows signs of leaking as you set out to do. I've never had (knock on wood) a cooler leak. The seals are pretty durable (they are captured nicely and really shouldn't fail). You'd think a small leak in the cooler would grow into a large one quickly with all that oil pressure, but maybe they don't. I had a small leak in a VW cooler once, and was certainly happy it was small as it happened in the middle of a leg of the Carrera Panamericana and by adding oil I was able to finish the day before I had to replace the cooler. However, it was pretty unmistakable as a cooler leak because it got oil to places a drip type leak couldn't have done. The discerning reader will notice that this general procedure of rotating the engine/tranny unit down using the compliance of the rubber in the tranny mounts is the same as the procedure you can use to remove the entire engine without having to remove the tranny also. Except you don't have to remove quite as many fuel lines and such, and needn't jack the car up as far. Good luck. Walt Fricke |
Eva
Hot tip:
A complete engine/trans drop takes marginally more time. Don't waste your time with a partial...and definitely don't try to separate motor and trans with trans in car
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
911SauCy,
That logic escapes me. Why do extra, just because you can? |
No way I would do a full engine drop for a hose and oil pressure sensor. I haven't done a partial drop in some years but maybe a 90 minute job. Lowering the engine 3-4 inches really opens up the area you need.
I'm glad someone has already linked our "How To" Tech Articles, there is a plethora of helpful guides there written by Pelican's founder Wayne and other Porsche experts.
Still here
I'll do a full drivetrain drop too but then I've to muck with the CVs, redo the clutch adjustment, play peg board with the tranny bolts and that's assuming I didn't forget any steps and nothing goes awry .... on second thoughts, the partial might not be a bad idea after all.
Partial drop gives plenty of room. BTDT to fix the triangle of death oil seep years ago, but I remember it well. Also a good time to replace the sound deadening pad - if you're into that sort of thing.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Eva
Maybe it's just me ![]() There is always something else to do
Targa_PB_78_SC
You probably do not need to go that low, not sure on the oil breather hose though. Just take care as things can shift a bit.
BareRearedRookie |
It is the sway bar which is my main PITA for pulling the tranny. An hour each way is pretty quick - A lift would help a lot - getting the car up high enough to get the engine out from under the car is tricky using jacks.
That Rennlist post was for a 2.7. The newer cars with oxygen sensors have a 12 pin connector to be disconnected also. Partial drop is the way to go for access for small jobs. I solved the idiot light leak issue by taking off the sender, opening it up, gutting it, drilling a hole down its middle, tapping it, and screwing in a bolt, with sealant, into the hole. This was about the 4th sender which failed, despite reinforcing its seal with epoxy. To retain the warning function, I bought a combo idiot light/oil pressure sender, which screws in where the pressure sensor goes, and just extended the idiot light wire to it. VDO makes these. |
i do the idiot light without even dropping the engine..I used 1/2inch socket extensions 27mm socket on the end.To guide it back in on the threads i use hard rubber pipe which fits over the oil press switch.I also remove the air booth and use mirror for better to see ... but it could hard for you...i imagine....
Ivan i only use an original German made oil press switches,i have an old stock parts..The new types do no last as Walt said.
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 07-02-2021 at 06:17 AM.. |
I used a bead of JB Weld around the plastic/metal where they meet. Seems to have held up for a couple of years now. Now I've said that guaranteed to fail.
Bead of epoxy.......
As of today, the pressure switch on my ‘78 Targa is still working and no sign of oil leak around the pressure switch. The rubber diaphragm inside the pressure switch is the first to fail and will cause oil to leak. The new pressure switch are no longer made in Germany. They are made in some far away country were quality control is notorious but the price is cheap. Last time I bought one was about $7. Tony |
Glenn,
Picture of the motor I am working today. ![]() ![]() The pressure switch with epoxy bead is my signature. I have been doing this trick for a long time with incredible success. Tony |
Wazook84
My 2 cents is to just do a partial drop. It is NOT much harder to remove the eng/trans completely but it IS stressful trying to line up the tranny bolts while your $10K power plant is balancing in mid air. I've done both ways many times and will take a partial whenever possible.
Good Luck and be safe, never trust hydraulics with your life/limbs. Scott |
Still here
Is that with a lift or the poor man's double jack tango ?
