Passionate Noob
Weird, now I show as 313green - my original username. Oh well. 313green=Mike8819
Passionate Noob
found one of my old posts with my beloved 72
Good news bad news! |
Mike,
Your SC's body was zinc dipped. If you're headed all the way down to the metal, use a process that leaves the zinc? |
Mike --
Slightly off topic, but what airhead BMWs did you own? I had a '72 R75/5 and a '75 R90/6. I had the /5 for decades and the /6 for about 10 years (i never should have sold the /6, what a great machine!). John '81 911SC Targa |
75/5 Toaster tank and a R90s. And a K-bike. Sent from my iPhone using Tapatalk |
Man, I love this color. I'd just R&R where necessary. Great find!
Slow old car
looks like a ROW car, but has an emissions pump? interesting.
great color- enjoy it!!
Mike 1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX |
Passionate Noob
Taillight assembly removal
Hey gang, Im back with my SC in hand. I've begun the teardown.
Question - how do I remove the taillight assembly housing wiring plug? I don't want to break any wires. I am going to remove the entire assembly for paint and to refurbish the assemblies. Thanks.. MM
When you own the car, you can do whatever you want to it. It is yours, don't worry about what criticism you may get from others....
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Full Send Society
Aside from a very few special 911s, these were mass produced and frankly once you’ve seen one you’ve seen them all. What makes the Porsche culture so much better than most other vintage car scenes is the way owners chop, tweak hot rod and outlaw their cars to be extensions of themselves. That so much more interesting than another clean factory example 911.
Go for it and share!!
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
This car has been sitting for years. Only used as a Hollywood prop car. It also served as a lovely squirrel hotel. It needs alot of work, needless to say.
ROW '78 911 Targa
Once you get a little pushed past the sheet metal it will go easier. Use Dow 111 to lubricate the rubber when you go to install them back in.
![]() ![]() Sent from my iPhone using Tapatalk |
Btw. Another topic - I tried to remove a small dent on the fender using the Eastwood paintless kit. Didn't work and only managed to pull the paint off. Fortunately I'm repainting but heads up if you use this on stock paint. Might damage the paint.
Kind of Blue
Just make sure you get the right eBay sticker package.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Rear bumper and tail removed . Can I bondo the old bolt holes? Also does a standard SC grille fit the decklid? Or better to find a used non-spoiler decklid?
Thx. ![]() Sent from my iPhone using Tapatalk |
Don't know about doing an "Outlaw" build, but you certainly can make a scoundrel !
Passionate Noob
I posted this a while back. I was planning on starting my outlaw (scoundrel) project and hit a few snags. Thought I needed to sell the car but fortunately I hung on...
I might as well document as much as I can. I will try to post questions and pictures. Thank you so much in advance. I have another thread where I can color-shift your Porsche paint (as a thank you). Give Back to the Forum ... ? |
Passionate Noob
Today's Help - Dansk Fuel Tank
Just received mine. Came with directions. I was unsure what they meant by 'removing the spray-in liner", Does that occur when I do swirl and rinse with carb cleaner? Just want to make sure I do it right.
Passionate Noob
Updates and pictures
This car has a fun history. Its past life was as a Hollywood prop car. Video of the car in Goliath (with Billy Bob Thorton) being driven by David Sedaris...https://youtu.be/DFpSaZtYPio
The car baked in the CA sun. Needs alot of work. I brought it back to Mi (with the help of @techweenie). The motor and trans are being done now. Keeping it stock. Ive stripped the car and am working my way through everything. Ive been focused on engine and trunk area. Full of nuts, dirt and whatever else the squirrels brought home. I pulled the light housings and cleaned, repainted. I stripped the interior and will add square weave carpet. Seats are being reupholstered. Went with VTO classic wheels and Pzero tires. Lots to do and I'll have questions. I am a noob, after all. ![]() Lastly, if you need parts, see my other thread. I'll also have the fuel tank available soon. Seems in decent shape. SC parts sale - mostly exterior Mike ![]() ![]() ![]() ![]()
