ericwitte's Avatar
Send a message via AIM to ericwitte Send a message via Yahoo to ericwitte
Just finishing the build of 3.4: Mahle 98mm, Xtreme CNC’d heads, MK Long tube headers, Sal’s MAF, bored TB, supertec, ARP, 964 cams and Andial extrude honed intake (last 2 were on the original euro 3.2 with an authority MAF and chip and the car was very fast). Car should be finished by October...curious to see what the dyno shows once broken in
996 Coupe, 84 Euro Carrera, Cayenne S, BMW CS 30, 72 2002 Ti (gone)
72 911 Hot Rod, Healey 100M, Giulia 1300 Ti, Merc 280SE4.5
Colorado Grand 03-04-05-07-08-11-17-18 Tour Auto 04-05
RG #650
Old 08-26-2021, 08:51 PM
Update on the project: Ended up being a complete rebuild of the engine
Went with:
- 964 Cams
- 98mm Mahle kit 3.4L conversion
- ARK Hardware
- Single plug
- Motronic with Custom Steve Wong Chip
- 3.2 Enlarged Throttle Body Conversion https://www.911chips.com/engine.htm
- 991 GT3 Muffler
- Custom headers from Rarelyl8. See https://forums.pelicanparts.com/porsche-911-technical-forum/1076156-project-997-991-gt3-exhaust-911-3-2-a.html
- Renovated alternator fan
- New fuel lines
- New oil lines
- New oil pump
- Chain Tensioner Update
- Wevo Semi solid engine mounts
A few photos:
Old 03-05-2022, 12:47 PM
I'm still waiting for the ECU, Throttle bodies, renovated alternator fan to arrive. I'll keep you all posted.
Old 03-05-2022, 12:48 PM
Went with:
- 964 Cams
- ARK Hardware
- Single plug
- 991 GT3 Muffler
- New fuel lines
- New oil lines
- New oil pump
Interesting, I'm doing a similar build but am using a 964 crank.
Did you upgrade your fuel injectors to do the conversion to 3.4? Is it considered necessary?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 03-05-2022, 02:03 PM
No, keep stock. I should say that I'm doing this renovation together with my mechanic, so I have a helping hand on side here.
Old 03-06-2022, 08:48 AM
Eng-o-neer
Tremelune's Avatar
I hate seeing gorgeous engines because I'm usually happy with my dirty one...
Can you talk about more about the 991 GT3 exhaust decision? How does it compare in terms of noise and weight compared to stock? I have a 3.0 lying around that I'll need a muffler for...I was going to use a stock Bischoff, but the idea of having a switchable quiet/loud muffler instead of a not-too-loud muffler is compelling. I was gonna get SSIs, but it seems your headers are on the custom side...?
Old 03-06-2022, 05:27 PM
Steve told me to keep stock injectors and that 75% of the 3.45litre motors he has tuned, worked fine on them. His website also suggests that the limit of the stock injectors is 250hp. I'm assuming he means wheel horsepower.
Time will tell.
Always learning.
Old 03-07-2022, 12:51 AM
This isn't quite what you are after, but I ran a 997 GT3 muffler on my 3.0 with itbs, big cams and headers. This is only using the quiet ports...
Always learning.
Old 03-07-2022, 12:53 AM
Is it possible to get an update on how the car has changed since you've had a the mods a few months ago. Did I read that you daily drive this?
Also, did you convert to MAF or keep the speed density?
Old 06-10-2024, 06:50 PM
fallingat120mph's Avatar
Hi all,
I'm having my engine rebuild on my 1987 911 Targa, as after 106k miles I had excessive oil consumption. It was supposed to be a top-end rebuild, but now that we have dropped the engine, it's evolving into a full rebuild due to leaking main 8# bearing, worn valves, worn cylinder heads, and worn Alusil cylinders + pistons.
I want to keep the car reasonably stock since it's a Targa and a daily driver, but if I anyway will be I'll be in the market for a new cylinder+piston set, I'm currently trying to decide whether I should keep the engine stock 3.2 with a set of Nickies, or I should bite the bullet and go the 3.4L conversion with the Mahle kit?
The car will be fitted with a 997 GT3 muffler + rarelyl8 long tubed heat exchangers, so there should be plenty of air.
My options:
Option 1: Keep motronic + single plug + Steve Wong chip + 964 cams + ARP hardware + AASCO springs + 95mm Nickies with EU/ROW compression
Option 2: Keep motronic + single plug + Steve Wong chip + 964 cams + ARP hardware + AASCO springs + 98mm Mahle kit 3.4L conversion
What would you do and why?
I appreciate your input!
/k
Doing almost the exact same improvements...was there ever an outcome to all of this?
Erik
1986 911 Coupe
1986 911 Targa
Old 03-25-2025, 09:12 AM
