Just finishing the build of 3.4: Mahle 98mm, Xtreme CNC’d heads, MK Long tube headers, Sal’s MAF, bored TB, supertec, ARP, 964 cams and Andial extrude honed intake (last 2 were on the original euro 3.2 with an authority MAF and chip and the car was very fast). Car should be finished by October...curious to see what the dyno shows once broken in
996 Coupe, 84 Euro Carrera, Cayenne S, BMW CS 30, 72 2002 Ti (gone) 72 911 Hot Rod, Healey 100M, Giulia 1300 Ti, Merc 280SE4.5 Colorado Grand 03-04-05-07-08-11-17-18 Tour Auto 04-05 RG #650 |
Update on the project: Ended up being a complete rebuild of the engine
Went with: - 964 Cams - 98mm Mahle kit 3.4L conversion - ARK Hardware - Single plug - Motronic with Custom Steve Wong Chip - 3.2 Enlarged Throttle Body Conversion https://www.911chips.com/engine.htm - 991 GT3 Muffler - Custom headers from Rarelyl8. See https://forums.pelicanparts.com/porsche-911-technical-forum/1076156-project-997-991-gt3-exhaust-911-3-2-a.html - Renovated alternator fan - New fuel lines - New oil lines - New oil pump - Chain Tensioner Update - Wevo Semi solid engine mounts A few photos: ![]() ![]() ![]() ![]() ![]() ![]()
![]() ![]() I'm still waiting for the ECU, Throttle bodies, renovated alternator fan to arrive. I'll keep you all posted. |
Interesting, I'm doing a similar build but am using a 964 crank. Did you upgrade your fuel injectors to do the conversion to 3.4? Is it considered necessary?
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
No, keep stock. I should say that I'm doing this renovation together with my mechanic, so I have a helping hand on side here.
Eng-o-neer
I hate seeing gorgeous engines because I'm usually happy with my dirty one...
Can you talk about more about the 991 GT3 exhaust decision? How does it compare in terms of noise and weight compared to stock? I have a 3.0 lying around that I'll need a muffler for...I was going to use a stock Bischoff, but the idea of having a switchable quiet/loud muffler instead of a not-too-loud muffler is compelling. I was gonna get SSIs, but it seems your headers are on the custom side...? |
Time will tell.
Is it possible to get an update on how the car has changed since you've had a the mods a few months ago. Did I read that you daily drive this?
Also, did you convert to MAF or keep the speed density? |
Doing almost the exact same improvements...was there ever an outcome to all of this? Erik
1986 911 Coupe 1986 911 Targa |
