RETIRED
Joe Bob's Avatar
SC door lock problem
My driver door lock doesn't want to lock manually or with the manual wheel in the door card. It WILL lock and open with the key.
Can I just dribble some lube down the hole or do I need need to remove the door card and do a search for Nemo?
2012 ML350 3.0 Turbo Diesel
Old 08-02-2021, 01:44 PM
Just had my door opened up to check the locking - no fun.
There is at least one 'rod' behind the card that connects to the manual wheel.
It has plastic connectors that can come loose, or fail completely.
The key bypasses the rod mechanism.
Possible culprit:
993-531-563-00 - Pelican has them
1986 911 turbo - less than 30k miles
Old 08-03-2021, 04:07 AM
RETIRED
Joe Bob's Avatar
I backed the plunger out and it works, a little stiff but it works.
Old 08-03-2021, 07:50 AM
Maybe you dodged a bullet!
WD40?
Old 08-03-2021, 08:07 AM
RETIRED
Joe Bob's Avatar
No lube....can't find the damcan....
Old 08-03-2021, 08:08 AM
Wildman Emeritus
Don't overtighten the screw for the knob when you reassemble. I did and it created an impingement which made the knob difficult to turn.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 08-04-2021, 05:54 AM
theiceman's Avatar
if you ever get to take the whole mechanism you should , its actually an engineering marvel when you figure out how it all works. I was fortunate enough to get a bag of those tine plastic fittings for the linkages at Hershey for a buck..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 08-04-2021, 10:38 AM
group911@aol.co's Avatar
Sounds like it's due for a good disassembly and cleaning. On your cab, at least you only have to pull the back window guide.
Make sure you put a good moisture barrier back on before the door panel.
Thanks,
Bob
group911@aol.com
Old 08-04-2021, 12:37 PM
Designer King
Paulporsche's Avatar
On my car, I found that the little grip that rides up and down in the garnish strip became too tight in its hole. Seems as though the black plastic insert closes up somewhat over time (lol 45 years!).
I opened it up by reaming it out with sandpaper. Once that part was able to move freely, the whole mechanism became easier to work.
While I was fooling around I also sprayed some lube in the general direction of the locking mechanism, incl inside the lock and by opening slightly the door card, all of which seemed to help.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-04-2021, 06:36 PM
