LinkBack | Thread Tools | Rate Thread |
I am guessing they didn't sell very many of them, not a very big market segment to start with. Plenty of people are fine with the stock radio or their JVC from the 2000s.... I just bought another one and overpaid for it in case there isn't a successor.
'95 Coupe (2025-??) '86 Coupe (2021-2025) '82 Targa (2018-2022) |
Did any of you update a working one? And if so, did it still work after the update?
Brian 87 Black/Black 911 Coupe Gone: 01 Rainforest Metallic Green/Savannah Beige 996TT Coupe; 90 964 C2 |
Have not read any account of firmware update bricking unit. |
Just for people doing searches in the future, I will leave the link to my OneDrive up for a while. It my get deleted some time in the future when we are cleaning up old files and the link will no longer work. Just send me a PM and your email address and I will email it to you.
The firmware update is easy. Just be sure to put just one of the firmware files on the thumb drive, not both! Read the instruction I posted earlier in the thread. It is fast and easy to do and safe.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Important to note - ONLY use the upgrade IF your unit isn't working otherwise you can destroy the unit. I just got a Bremen and it's working just fine.
'76 912E '73.5 911T '72 2002tii '88 M3 '17 Mini S |
The important thing is to check the version of your unit to see if it's up to date. I received my radio a couple weeks ago and it was already at the latest version, 52X.
It's easy to check your current version. Here's the changelog. Changelog BREMEN SQR 46 DAB (2001018000000) P9A22031 - First release P9B15034 - added DEMO MODE with color change - added more colors 512 > 4096 - BEEP default changed to OFF P9C10038 - Production release P0115039(X) - DAB: Presets stored permanently even after new SERVICE SCAN - DAB: Improved timing of > keys for selection of DAB SERVICE - Bluetooth: Reconnect to source BT-STREAM after ACC OFF/ ON if available - Issue: Sometimes wrong DAB channel display (X- Version only) P0313043(X) - added: BEEP confirmation for PRESETS even if BEEP is OFF - added: PRESET+ / PRESET- for SWC commands - changed: SWC compatibility (58mV) - fixed: channel display with new DAB module (X- Version only, not verified) - added: compatibility with SWC commands of some pioneer compatible interfaces, e.g. connects2 (default setting, no SWC setup needed) - issue: SWC1 / SWC2 reversed for preprogrammed keys - issue: DAB presets not saved anymore after new SERVICE SCAN/ INTRO SCAN P0317044(X) - fixed: SWC1 / SWC2 reversed for preprogrammed keys - issue: DAB presets not saved anymore after new SERVICE SCAN/ INTRO SCAN - issue: SWC PRESET+/ PRESET- does not properly on DAB (changes ENSEMBLE instead of PRESET) P0318046(X) - fixed: DAB presets not saved anymore after new SERVICE SCAN/ INTRO SCAN - issue: sometimes wrong channel info displayed on DAB if displaymode is set to FREQUENCY P0323047(X) - added: show A2DP streaming info TITLE/ARTIST/ALBUM (select via DIS), capability may depend on used phone/ mp3 player and production date (only models with bluetooth version B20191226 and higher are supported, please check in MENU - VARIOUS - VERSION). - fixed: SWC PRESET+/ PRESET- does not properly on DAB (changes ENSEMBLE instead of PRESET) - fixed: sometimes wrong channel info displayed on DAB if displaymode is set to FREQUENCY P0701049(X) - fixed: BT pairing issue on selecting STREAMING (shows accidentally PIN before starting pairing) P1310050(X) - changed: BT AUDIO MIX volume optimazion for higher volume levels (BT AUDIO MIX volume increases in proportion to the MAIN volume ). Please note: Completely proportional volume change is not possible, this is hardware related. P1310052(X) - fixed: Permanent memory issue of some settings (FAD/ BAL) |
I received and installed my Bremen SQR 46.
I was prepared to install the update but looked at the version on my unit, (P1625107X), which looked to be newer than what was in the zip file. Am I reading this correctly?
************************* Socbum '88 911 Coupe |
Agreed, your version seems newer
Would be nice to get firmware access again. I had the original firmware, so the one linked here fixed my issue with bt-streaming not coming back on as a source when I got back into the car!
1971 911T (Tangerine) 1973 911T (Light Yellow) 1978 911SC -- "Northy" 3.2 twin plug 1990 911 Carrera 2 |
I will need to check mine too, the BT comes on immediately but the fader setting doesn’t hold.
CURRENT: 2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black 1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue 2024 Macan White, Beige / 2010 Cayenne White, Black PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey |
Thank you for posting this. I hope that (finally) my fader settings will "stick"
2009 Carrera 4S, PDK 1990 964 Targa 2018 Range Rover Velar |
Does anyone still have the latest firmware they can share? The link Glen posted above is no longer working.
send me an e-mail to czulrich AT gmail DOT com and I can send it to you
Here's a link: https://1drv.ms/u/s!AksntBvn1P1Tkf8AGlqS0VRZZFMj7w?e=8XhWeC
Two things (from the generous person who shared with me): a) Make sure you read and follow the README file b) The upgrade only worked for me when I plugged the USB drive into the front of the radio, (I first tried with the rear input which failed) Last edited by darrin; 11-26-2021 at 12:50 PM.. |
Thanks to both of you gents, worked a treat. I'd upgraded it before but had an older version on there.
Only problem I had was apparently my first USB stick was faulty, as the radio got stuck alternating between "READING" and "WRITE ERROR", which scared the crap out of me. Fortunately just popping in a different USB stick with the file fixed it and it updated correctly. |
I could sure use the latest update for my Bremen SQR DAB Radio. I bought the radio 12/20 and just haven't had the time to do the install. Getting ready to install in the morning. Anyway, is the FINAL update:
LU5350-S62(P1420052)? -BILL
"If you're not living on the edge, then you're taking up too much space." My 1979 930 1979 930- 3.4L Andial Racing P/C's/Fuel Enrichment System/Adjustable Boost Control,Euro Fuel System,Group B Cams,K27 Turbo(1.0 Bar) Andial Intercooler, GHL Muffler/SS Header Sys,Welt. SS Kit/Camber Brace, SS Brake Lines, 350mm Momo, Billet Pedals, 9x17 - 11x17 Fikse. 1999 FXSTC- Harley Davidson HI-4 Ignition,Thunderball Cam,Mikuni 42mm,Vance & Hines 2003 Jetta Wagon GLS 1.9L TDI 1993 GMC Jimmy 4x4 St. Louis PCA - Member Kirkwood H.O.G. Chapter #2573 - Member Gateway H.O.G Chapter #1337 - Charter Member |
Bill -- it's the most "final" version that I'm aware of. If anybody has a later version, send me a private message, I'm happy to host it/update my link above.
Thanks, Darrin! -Bill
I just bought a unit this past week. Wanted to share that it came with a newer version that available in this thread:
P1827201X <- installed P1420052X <- thread download Wish I could rip it from the HU for y'all and share it. But perhaps knowing this is out there will help. |
I go back and forth on keeping the modern Alpine that the PO put in, reinstalling the original or buying one of these. I've seen some mixed reviews and hopeful the latest firmware has addressed any issues. From which vendor did you buy the radio?
1989 Carrera Former flings... 2009 Carrera S (x2), 1986 Carrera, 1997 993, 1983 911SC, 1995 993, 1987 Carrera, 1985 Carrera |
