Classic Retrofit and Old Headlight Fuse/Relay Connections
I'm installing a Classic Retrofit fuse box from our host. My car has a non-kit headlight relay setup installed, and I don't know how to integrate it with the new fuse box's fuse/relay system.
In my current system, wires were run straight from the ignition-switched power (top of fuse #7 from left). Those wires ran through two fuses and to two relays. One for high beams, one for low beams. The relay wiring is shown below. ![]() The schematic for this section is shown below. L1 - Left headlight L2 - Right headlight S5 through S8 are fuses 5 through 8, apparently numbered from the right-hand side of the stock fuse box. ![]() Based on the picture below from the fuse panel seller's website, I should connect the white wire into top of the pair labeled 1 & 2, immediately left of the relays. I should wire the solo solid yellow wire into the top of the pair labeled 3 & 4 immediately right of the relays (3 & 4 are not bussed together on my panel, so I should add a jumper). Then blue goes to bottom of 1, blue/white goes to bottom 2, green/yellow goes to bottom 3, and other yellow (from pair) goes to bottom 4. However I have no idea where the red wires are supposed to go. ![]() That's my best guess as to which fuses to wire to in the new fuse panel. If anyone knows for sure, I would appreciate your input! Edit: After more research and analysis, it looks like I don't need the red wires at all. Just hooking up the other wires as I indicated above. The manual for classic retrofit says power is run internally through the block.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! Last edited by OsoMoore; 08-15-2021 at 06:31 AM.. |
Update: I hooked up the wires using what looked like the old/correct wiring.
I found the following issue: Low and High Beam Fuses In: Neither highs nor lows work. High Beam Fuses Only: Neither highs nor lows work. Low Beam Fuses Only: Low beams work, when I try to switch to high the lights flicker and a relay buzzes nonstop.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! |
Relay wiring
I think I see your problem.You can't run the same power wire (from switch) to feed both the high and low relays. The yellow wire from the switch should only go to the low beam relay and the white wire from the switch should only feed the high beam relay. Everything else looks to be ok. It would help to know what year your car happens to be!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
ROW '78 911 Targa
Top fuse wiring looks ok. But I’d move the white wire in the top of fuse 8 over one to the right to go in fuse 7.
Can’t see what is coming out the bottom of each fuse 5-8 going to the lights though? What are the red wires that look like they are coming out the bottom of fuse 8? Should be wired with the colors exactly the same as in the schematic. Only one wire out of each of 5 and 6 for the low beams, and one each to the high beams (plus the hi beam dash indication wire bottom of 8) for 7 and 8. Porsche schematics count the fuses from the headlight end to the dash. Ignore the markings on the cover or on the fuse panel…
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 08-15-2021 at 10:04 PM.. |
ROW '78 911 Targa
Here is a photo of mine from when I replaced my dash harness a month ago and installed the same fuse panel.
Fuse 5 and 6 are low beam. 7 and 8 are high beam. Wish I had a better photo, but carpet is back in now. I chose to use fuse 5 instead of 6 for the low beams input on top.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 08-15-2021 at 10:23 PM.. |
ROW '78 911 Targa
Looking at your photo more. What color wire is coming out of the bottom of fuse 6 that has the yellow wire the the terminal on top? If it is white/blue it should go to fuse 8 two to the left and there should be a yellow/green wire at the bottom of fuse 6.
Hey folks, for thanks for the input. Here are some pictures of my box (the picture earlier was on the installer's website.) Full description of my setup is below the images.
![]() ![]() The car is a 1979 911 SC. This is the Classic Retrofit fuse panel, so there is a built-in relay kit. The installation instructions say to return things to stock, and the panel's internals will handle the relay work. I don't know for sure what is stock, but I'm pretty sure I've gotten there now. My connections are: High Beam feed wire (white) is spliced into blue. That blue wire goes to the top of the high beam pair (which are bussed internally) on the left of the relays. That's positions 7 & 8. On the bottom of 7, I have the blue wire with the white stripe. On the bottom of 8, I have the blue wire and the white wire with a blue stripe. Low Beam feed wire (yellow) leads to the top of 6. There's no internal bus, so I have the copper jumper between 5 & 6. On the bottom the green/yellow wire is connected to 6, and the yellow wire is connected to 5. Since my earlier testing, I added an improved ground wire to the fuse panel board. The full behavior can be seen in this video. Test starts at 45 seconds: https://youtu.be/E0EcOfFAQz8 What the video shows is when I turn on low beams, they come on just fine. When I flip on high beams, they come on but a relay buzzes nonstop. If I pull out just the low beam fuses, I get no low beams and also no high beams. If I pull out just the high beam fuses, I have low beams, and buzzing when I try to turn on high beams (but no actual high beams). When the relay is buzzing here, the low beams are dimmed.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! Last edited by OsoMoore; 08-16-2021 at 04:46 AM.. |
Tim's questions: I can move the white wire from 8 over to 7. Theoretically they should be the same due to the internal bus. But I'm happy to try anything. Do you have the internal bus for 5 & 6? My board isn't marked with one, which is why I put in the copper jumper. As noted above, I have the colors at the bottom of the panel looking correct. Update: I might be having the issue because I only have mounting screws at the ends of the fuse panel, and not in the middle spots in the panel. It might be relying on a middle screw for ground for the relays. I haven't had those middle screws in years. Does anyone know what spec they are offhand? I can always pull out one of the end ones and take it to the store to match, assuming they are identical.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! Last edited by OsoMoore; 08-16-2021 at 05:07 AM.. |
That may be your problem....missing ground on the relays.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
ROW '78 911 Targa
Did you confirm 5/6 are not connected up top with a meter?
Mine works fine using 5 for low and 7 for high as the only relay inputs. Maybe I read something in the instructions that said go to 5?
Ding ding ding! Classic Retrofit confirmed this was the issue. I added a screw to the middle spot with a good ground and now there is no more buzzing. But wait, there's more!
Now, once I turn the headlights on, I can never turn them back off. I have to disconnect the battery. Turning switch off, ignition off, and removing the key doesn't turn them off. Quote:
1) Disconnected the low beam feed wire (yellow) that was at the top of 5&6. Removed the bus I had put in between 5 and 6. Verified 5 did not connect to 6 without the bus. 2) On a whim, checked if 5 was connected elsewhere. Found 5 was connected to 2, 3, and 4 (according to my continuity test multimeter). 3) Pulled all the fuses for 2, 3, 4, 5, and 6. 4) Found 5 was now only connected to 3. Again, note that the yellow feed was removed from 5/6. Yet without any fuses, 5 was connecting to 3. I've got a video I took that I can post in a bit. Very odd! EDIT: Videos of the weirdness: https://youtu.be/4XvDYqA6zBc https://youtu.be/4eNMIPBQAdM
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! Last edited by OsoMoore; 08-16-2021 at 04:05 PM.. |
ROW '78 911 Targa
Normal… You are measuring through the bulbs and back unless all wires and fuses are removed.
Hmm, I was wondering why five would connect to three when five had no fuse and no wire from the headlights either (video 2). But maybe I am misunderstanding something about it.
ROW '78 911 Targa
If you are testing the fuse panel itself, remove all wires and fuses.
Otherwise you are measuring through all devices connected to it that have possible paths back. Light bulbs being a prime example. Goes through headlight lamp to ground and back from ground through the tail lights or front running lights. Both front and rear running lights and license plate lights come off of fuse positions 2,3,4. Fronts are fused, rears are not.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 08-16-2021 at 05:54 PM.. |
On their website are PDF instruction which include a separate page for the relays, I removed my Jwest relays and used their on board relays following those instructions and had no issues
I ll post a picture later today |
That would be appreciated. I tried to match stock with my wiring, but seeing as I never owned the car with a stock or official relay kit, I'm not 100% sure.
ROW '78 911 Targa
Pull the 4 fuses for the hi/low lights.
Do relays still pick up in both hi or low beam selection? If yes, inputs are correct. If not, then the blue and/or white wire(s) need to swap positions from bottom to top. (Either one or both depending on what happens for hi/low selection and relay action.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 08-17-2021 at 08:00 AM.. |
Sounds like a good task for having a helper. Fortunately my wire loves riding in the car.
Please don’t link F5 & F6. The yellow wire should be in 6 (next to the relay). 5 bypasses the relay as per European models that use a electronic dim/dip circuit that cannot be switched with a relay.
