Compression Test + Leak Down Process?
Hello Pelicans,
I want to do a compression test and leak-down test.
The proposed sequence:
1 - warm up engine
2 - remove AC compressor/etc.
3 - remove all plugs
4 - compression test cyl. 1 then leak-down test cyl. 1
5 - do #4 until all 6 are done
6 - install new plugs
7 - install other stuff
The question is should I do all the cyls. compression test and then go back and do the leak-down tests? The means I would have to thread in the Stomski extender again on all cylinders.
The leak-down test might take a while because I will have to adjust the pressure on the incoming gauge if the regulator doesn't keep it right on. I plan to test with 80psi on the incoming gauge. I'll calculate the % after to compensate for not using 100psi.
Thanks.
-Henry
Sold: 1989 3.2 coupe, 112k miles
Old 09-05-2021, 06:48 AM
Uncertifiable!!!
Uwon's Avatar
Following….
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 09-06-2021, 04:22 AM
okay - I'll post results here.
It seems the people on BaT want both and having a record of results might help others.
Old 09-06-2021, 07:46 AM
If you want to follow along.... I started a thread here.
Need advice - Leak-down great, Compression test not so much
Old 09-19-2021, 11:47 AM
The engine says hot for a long time so rushing is not really needed. Getting the plugs out and having a setup to make the leak-down and compression tests get connected to gauges that work is needed.
Old 09-19-2021, 11:49 AM
Brew Master
cabmandone's Avatar
I was told that you do a leak down test stone cold.
Nick
Old 09-20-2021, 03:09 AM
T77911S's Avatar
I don't do either hot.
for one its a pain working on a hot motor.
two what about temp differences from start to finish.
not worth it in my opinion.
people also say to hold the throttle wide open. I never see any difference.
as long as you do them all the same way is what matters.
I would check head bolts and do a valve adjustment first.
just check to see if any are broken.
pull the fuel pump relay
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-20-2021, 06:33 AM
