Broken Spark Plug
![]() What do you think caused it? |
Senior Member
If you show a pic of the broken end, some of the many engineers here could offer educated guesses. Me? Manufacturing defect is my guess.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Functionista
What’s with the marks on the screw on tip? Looks like it’s been overtightened or suffered some trauma causing part to fail further down....
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Threads corroded. Plug wrench on cock-eyed/not properly engaged. Then max torque. Usually some combination of the above.
Neve seen one snapped like that with the ceramic still intact.
Sent from my iPhone using Tapatalk |
I’ve had four out of six go like that when I removed them from my 2.4S recently, same brand and make as OP.
Functionista
Counterfeit comes to mind….
Flat Six
Center electrode broken, looks like axial failure (twisting load, not side load). Since the electrode's broken but not the ceramic insulator (and based on the marks on the aluminum ferrule), I'd guess someone overtightened the screw-on ferrule w/pliers. BTW, a 9-range plug is really cold . . . .
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Maybe it was an over tightened ferrule? I tightened them by hand. They always seem to be loose out of the box. They are in my 83 SC ROW. The cold plug helps with detonation.
Maybe the plug was dropped before it was installed.
Dave K |
First time I changed plugs on my '68 I had that happen. No cracks or break in the ceramic at all, just the center electrode (and about in the same place)
Roger 1968 sand beige 911 Normale coupe #11830091 1984 metallic moss green with champagne interior 911 Carrera coupe 2012 silver with red interior Boxster |
Thank you for all the input! I’ll keep you posted. I tightened the ferrule on the replacement plug, too.
Functionista
I tighten the ferrule with smooth jaw pliers. Leaves no mark and they are tighter than hand tight but not too tight (because clamping/turning pressure is low).
