Demetri's Avatar
Broken Spark Plug
What do you think caused it?
Old 09-05-2021, 01:18 PM
Demetri's Avatar
Old 09-05-2021, 01:20 PM
Senior Member
Superman's Avatar
If you show a pic of the broken end, some of the many engineers here could offer educated guesses. Me? Manufacturing defect is my guess.
Mocha 1978 911SC. "Coco"
Old 09-05-2021, 01:52 PM
Functionista
manbridge 74's Avatar
What’s with the marks on the screw on tip? Looks like it’s been overtightened or suffered some trauma causing part to fail further down....
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 09-05-2021, 02:31 PM
Threads corroded. Plug wrench on cock-eyed/not properly engaged. Then max torque. Usually some combination of the above.
Old 09-05-2021, 09:46 PM
DerkPerk's Avatar
Neve seen one snapped like that with the ceramic still intact.
Old 09-06-2021, 05:40 AM
I’ve had four out of six go like that when I removed them from my 2.4S recently, same brand and make as OP.
Old 09-06-2021, 05:59 AM
Functionista
Counterfeit comes to mind….
Jeff
74 911, #3
Old 09-06-2021, 06:17 AM
Flat Six
Flat Six's Avatar
Center electrode broken, looks like axial failure (twisting load, not side load). Since the electrode's broken but not the ceramic insulator (and based on the marks on the aluminum ferrule), I'd guess someone overtightened the screw-on ferrule w/pliers. BTW, a 9-range plug is really cold . . . .
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 09-06-2021, 09:27 AM
Demetri's Avatar
Maybe it was an over tightened ferrule? I tightened them by hand. They always seem to be loose out of the box. They are in my 83 SC ROW. The cold plug helps with detonation.
Old 09-06-2021, 09:49 AM
Dave Kost's Avatar
Maybe the plug was dropped before it was installed.
Dave K
Old 09-06-2021, 10:31 AM
rgrimm's Avatar
First time I changed plugs on my '68 I had that happen. No cracks or break in the ceramic at all, just the center electrode (and about in the same place)
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 09-06-2021, 02:06 PM
Demetri's Avatar
Thank you for all the input! I’ll keep you posted. I tightened the ferrule on the replacement plug, too.��
Old 09-06-2021, 05:48 PM
Functionista
I tighten the ferrule with smooth jaw pliers. Leaves no mark and they are tighter than hand tight but not too tight (because clamping/turning pressure is low).
Jeff
74 911, #3
Old 09-06-2021, 06:36 PM
