Windshield wiper problem
Hi All, I've just finished a full restoration of a 1971 911T.
I have trouble with my wipers. They go down before they go up when started. That means the park location is higher than the lowest point.
My guess is that the motor shaft is off by 90°. First, would you agree?
Second, do you have any images showing ingoing axle or any hints on to get to this?
Is this a fine splined assembly or is it a square making 90° adjustments?
I know I would have to remove the fan assembly but hope not to have to take the whole wiper assembly out. This will be some fun to do in the winter here in Sweden :I
Thanks for any input,
Jörgen Forssling
Gothenburg
SWEDEN
Old 09-18-2021, 04:09 AM
Rescuer of old cars
Arne2's Avatar
It's splined, not square. Can definitely be adjusted. You may be able to get to it from the inside through the gauge holes.
Run the wipers and then turn them off so that they park. Then loosen the nut that holds the lever arm to the shaft, and re-position the arm to point directly to the side. Yours is now probably pointing a bit up.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 09-18-2021, 08:45 AM
Thanks! I was just going to post a question about accessing it from the gauges. I think I will try that to start with.
And looking at some images and films of when I had my wiper motor assembly out I think I assumed right (as you confirm) that the lever is off.
//Jörgen
Old 09-18-2021, 09:21 AM
RETIRED
Joe Bob's Avatar
Yes gauge hole to access the nut, Wayne got this wrong in his book. Also consider parking the wipers on the passenger side.
2012 ML350 3.0 Turbo Diesel
Old 09-18-2021, 09:42 AM
Thanks! I guess I remove the bottom bolts of the "fabric-type supspension" and fold it out of the way to do this. Correct?
//Jörgen
Old 09-18-2021, 10:00 AM
MichaelSJackson's Avatar
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/69-Wiper_Reversal/69-Wiper_Reversal.htm
Since your there... Nice not to have them parked in front of the driver.
Old 09-18-2021, 04:27 PM
RETIRED
Joe Bob's Avatar
Except you don't have to go thru the front trunk or remove the blower motor......
Old 09-19-2021, 12:17 AM
Now it’s fixed!
Thanks everyone,
Jörgen
Old 09-19-2021, 02:08 AM
