Used in the Porsche 964/993 inductive discharge ignition systems, with a $100 Bosch dual channel ignition amplifier.
Dave |
Racer
Or, you are only using 3 of the 4 channels and each coiling is getting half power spark.....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
I’m only using 3 channels.
The spark on the exhaust stroke encounters much less resistance than the power stroke so the power is not split 50/50.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Ass-engine Nazi slot car -- PJ O'Rourke |
Racer
No, because waste spark. 2 work hard on compression stroke and 2 barely work on exhaust stroke.
Racer
Ok. From what I have read, the wasted spark on the exhaust stroke takes about 12% to 25% of the energy required on the non-wasted spark on the compression stroke. It would seem that each plug is getting, at most, only 38% of the energy it would otherwise get if the plug had its own channel.
