Originally Posted by rdimarco View Post
The Bosch twin coil 0221503035 recommended by Wayne at M&W has 2 separate coils in a single housing.
Used in the Porsche 964/993 inductive discharge ignition systems, with a $100 Bosch dual channel ignition amplifier.
Dave
Old 10-15-2021, 09:26 AM
Racer
winders's Avatar
Originally Posted by David View Post
It's a Pro-14 CDI. I'm not advocating using a 4-channel now since obviously a 6-channel is better and available but at the time there wasn't much else in a quality CDI. I did work with folks way more knowledgeable than myself to spec out the system and they felt it would work fine.
With that said, I don't see any issue driving 12 coils off a 6-channel CDI because you can wire it so that 1 coil is firing on a power stroke and the other coil is firing on an exhaust stroke. I would not wire two coils off one channel to one cylinder.
I looked at the docs for the Pro-14. It does not show a setup wiring more than one coil to one channel. Also, if you are using the 4 channel unit with 6 plugs, two of the channels are wired to two coils and two are wired to one coil, correct? If that is the case, two cylinders are getting full power spark and 4 are getting half power spark. Not good for consistent combustion in all cylinders unless you tune each cylinder individually (not likely).
Or, you are only using 3 of the 4 channels and each coiling is getting half power spark.....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 10-15-2021, 12:09 PM
David's Avatar
I’m only using 3 channels.
The spark on the exhaust stroke encounters much less resistance than the power stroke so the power is not split 50/50.
Old 10-15-2021, 12:17 PM
“Well, I’m making 475 hp at the wheels at .95 bar so not too bad. One of these days I’ll put a 6-channel CDI on it but there wasn’t one available when I built the engine.”
Ass-engine Nazi slot car -- PJ O'Rourke
David's Avatar
Sorry, a little brain fade on my last post: I am running 4 plugs off each channel so yes each plug is getting a little less than half the CDI power with the waste spark plugs drawing a little power. Certainly not ideal but the engine has run well for 12+ years with a few light track days.
Old 10-15-2021, 01:06 PM
Racer
winders's Avatar
Four plugs off of each channel? Wow. Isn't the ignition unit designed for one plug off of each channel? If that is the case, you are at 1/4 the power per plug......
Scott Winders
PCA GT3 #3
Old 10-15-2021, 01:26 PM
David's Avatar
No, because waste spark. 2 work hard on compression stroke and 2 barely work on exhaust stroke.
Old 10-15-2021, 04:42 PM
Racer
winders's Avatar
Ok. From what I have read, the wasted spark on the exhaust stroke takes about 12% to 25% of the energy required on the non-wasted spark on the compression stroke. It would seem that each plug is getting, at most, only 38% of the energy it would otherwise get if the plug had its own channel.
Scott Winders
PCA GT3 #3
Old 10-15-2021, 05:56 PM
