What is CIS
Hi everyone, would someone be so kind as to explain CIS vs non. I THINK it means Continuous Injection System. But does that mean carbs or mechincal injector?? I know its not electionic injection. Thanks this would make me feel a little less, ummm clueless.
Mike
Por-sche (Two syllables)
1973 Targa 911T (RIP)
1981 911SC
2019 Honda Pilot
Old 05-14-2003, 05:54 PM
magilla's Avatar
Actually, it is not Carbs, and I am pretty sure it is electronic FI. It is the system that came on 3.0 SC's (and maybe the 2.7's). I don't know much beyond that, but someone else will soon chime in with details.
Old 05-14-2003, 06:08 PM
CIS is the common name used for the Bosch K-Jetronic injection system. CIS does stand for constant injection system. It is not electronic (well, except for the pump which is powered by electricity). Here's a site that gives a pretty good description of the components and operation of the K-Jetronic system.
Good luck,
Jerry M
'78 SC
Old 05-14-2003, 06:18 PM
check this out
http://www.phat-gti.com/downloads/boschtech-12d.pdf
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
HarryD's Avatar
Try these sites:
http://www.auto-solve.com/mech_inj.htm
http://www.users.bigpond.com/INTERJECT/KSITEPLN.HTM
Basically put, k-jetronic is a simplifed version of mechnical injection where the metering pump is replaced by a mechanical flow sensor that adjusts a valve to meter fuel into the cylinders.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-14-2003, 06:25 PM
bigchillcar's Avatar
Yep, there's no lambda sensor or computer in these cars. Airflow into the airbox is what varies the position of the mechanical sensor. This is what meters the fuel flow which is ALWAYS flowing at one rate or another, depending.
Ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-15-2003, 02:12 PM
Unregistered
sammyg2's Avatar
My 1980 SC has a lambda sensor on the CIS system, the earlier ones don't.
Old 05-15-2003, 02:41 PM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Mike,
Welcome to the board. We are all clueless, it's just that some have more clues from experience than others! (I'm waiting the flames now )
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 05-15-2003, 02:42 PM
Gerald,
My bad...I knew that. Guess I was thinking early CIS because his car is a '73...
Ryan
Old 05-15-2003, 02:43 PM
Heck, I’m only 5 not 71!
targa80's Avatar
The 80 SC was the first year that the K-jetronics CIS with lambda was installled. 78SC and 79SC had just the k-jetronics CIS.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 05-15-2003, 02:46 PM
Randy Webb's Avatar
CIS is a hydraulically operated fuel injection system used on 911s from 1973.5 to 1983(?) when it was replaced by the Carrera's DME system. It is neither electronic nor mechanical, but uses vacuum. In its day, it was good for both emissions and economy, and was widely used on Eurp-peon cars. For a sports car, it is the work of the Devil and ought to be removed at once (if your state emissions laws allow that). It has horrible throttle response and does not make much power.
Old 05-15-2003, 03:57 PM
Targa Dude's Avatar
Send a message via AIM to Targa Dude
Here is a Site thats helped me out of several Pickles..
http://members.rennlist.com/jimwms/CIS/CIShome.html
Jorge (Targa Dude)
Old 05-15-2003, 04:04 PM
HarryD's Avatar
Sir,
I beg to differ. CIS uses a plate in the incoming air stream to detect and measure the incoming air flow rate. The plate is connected to a teeter-totter mechanism that adjusts a needle vlave to determine the fuel flow rate. There is no vacuum on this unit. Vacuum is used for various ancillary bits to "tune" the basic unit.
Much of the power loss problem with CIS is due to the lack of allowable valve overlap, which affects air and exhust gas management.
Respectfully submitted.
Harry
2020 MB E350 4Matic
Old 05-15-2003, 04:16 PM
Randy Webb's Avatar
We agree. It is the vacuum in the air stream that causes that metal plate to move.
Unfortunately it has a lot of inertia.
And, yes, the CIS system requires the screwed up valve/piston items.
Put on PMOs if at all possible is my advice.
Old 05-15-2003, 04:34 PM
Lorenfb's Avatar
Check out this website (systemsc.com).
It may be helpful for answering Porsche
fuel injection and ignition questions.
See ya
Lorenfb@aol.com
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 05-17-2003, 12:50 PM
Send a message via AIM to 69 911s
wasn't the original cis replaced by cis-e with the o2 sensor, basically upgrading it from hydro-mechanical injection to elctronically controlled hydro-machanical injection?
when you see hoof prints, dont automatically assume zebras
Old 05-17-2003, 08:42 PM
PRO Motorsports
Tyson Schmidt's Avatar
The lambda system is simply a piggy-back system where the electronic feedback can adjust control pressure via the frequency valve to change the mixture. So it's a form of mechanical injection that has an electronic device added on to more accurately meter fuel.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-17-2003, 08:49 PM
