Driver
Noah930's Avatar
High NO on smog test
I have an '87 Turbo. It's stock. I recently took it for its bienniel California smog test, and it passed. Motor was hot, full tank of 91 octane, O2 sensor is hooked up, etc.
But looking at the values, I noticed that NO is at the higher end of the allowable spectrum. HC and CO are well at the bottom of their scales, though. For my own education, what is the cause for this? Is it as simple as the motor's running lean? Please teach me something.
1990 Black 964 C2 Targa
Old 11-24-2021, 05:12 PM
My other ride is a C-130J
RNajarian's Avatar
I’d be curious to know too, but at least you passed.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 11-24-2021, 06:08 PM
RETIRED
Joe Bob's Avatar
My past experience is that when HC and CO are low, then the NOx is high. Fuel mix can be adjusted to raise the HC and CO and bring down NOx. I assume your Turbo has CIS. You can hook up to an exhaust analyzer and adjust the values.
2012 ML350 3.0 Turbo Diesel
Old 11-24-2021, 07:29 PM
Your engine is running too hot. Probably a little lean.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-24-2021, 07:38 PM
Diss Member
Quicksilver's Avatar
NO is a product of higher pressures during combustion. You only knock it down by reducing power or by using a three way catalytic converter. (The original 2 way catalysts didn't deal with NO and NO2.)
In the 80s Motronic Carreras they have a brown jumper wire that made the system retard the ignition by 4° to reduce the combustion pressure specifically to reduce NO for California's emissions. (So yeah, we disconnect the wire when it was time for a smog check.)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-24-2021, 08:02 PM
proporsche's Avatar
^^^^^^this^^^^^^i`d say the same^^^^
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-24-2021, 11:27 PM
FloydPink's Avatar
Do you mean connect the wire for smog? I was under the assumption that it should be plugged in to retard timing. On that note, I'd love to do a comparison between smog results with the brown wire connected/disconnected to see how much headroom it gives those of us with motronic.
Old 12-23-2021, 05:01 PM
That's my understanding as well. Hope we don't have it backwards!
Old 12-23-2021, 06:13 PM
HarryD's Avatar
NO is a product of high temperatures and a lean running condition. By slightly richening the mixture, you reduce the peak flame temperature and produce more CO and HC.
This chart is helpful To see how they interrelate.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-23-2021, 06:20 PM
My 86 carrera a couple weeks ago, I live in a “non enhanced” zip code (desert)
No no
Old 12-23-2021, 08:33 PM
EGR problems can cause high NOx, too. IIRC, 930's had EGR on both CA and FED cars.
It's still not terribly high. I'd be more concerned if it barely squeaked by.
Old 12-24-2021, 07:04 AM
