Analog Air Cooled
Hotshot's Avatar
My overvoltage issue solved, Engine blower motor fix idea?
After months of isolating circuits, a new ALTN, and a ton of head scratching I solved my random over voltage issue.
Turns out the Heater Blower Motor in the engine compartment was ticking and Arc’ing..hard to hear solo but thx to a friend we found it.
Upon taking it apart I found it was a rebuilt unit. Someone forgot the E clip on the back and that caused it to travel back n forth. That caused the brushes to cut into the windings and sort of on and off the commutator.
Cleaned up the commutator on the drill press. Bushings were fine. I made some new brushes.
Having a burned out orig one ( PO gave me all the old parts) and a friend giving me one that was dead ( brushes ) off an SC, I decided to re brush and fix the 2.
All was well until I put the last one back together and the brush holder board cracked. Turns out underneath was so brittle and charred.
I tried epoxy.. meh..
It kills me to spend $300 when I know it’s just a lil board. I like fixing vs replace. Any ideas?
Got one saved, hope to save two.
86 Targa
91 964
13 6 SPD Cayenne
Old 12-13-2021, 06:45 PM
Walt Fricke's Avatar
Find a source of that phenolic fiber board or whatever it is, take it to your local hydro cutter shop, have them make a new one? Use your obvious skills to reattach the various parts? Or would it be cheaper to find someone's throw away alternator and scavenge the part?
Old 12-15-2021, 07:22 PM
Analog Air Cooled
Hotshot's Avatar
Good idea. Not following the Alternator part though?
86 Targa
91 964
13 6 SPD Cayenne
Old 12-16-2021, 06:11 AM
It is pretty much like Bosch made those blower motors impossible to rebuild as a design feature. There are many blower motors in a 3.2 Carrera. All of them are crappy by design. I think the Chinese were inspired to build their products of today the Bosch electric motor way.
Old 12-16-2021, 06:16 AM
Analog Air Cooled
Hotshot's Avatar
Dansk sells knew ones, and they look different. I totally agree, of all the motors in our cars, these suck the most. Why not make them fixable. It’s 99% never the motor, or the squire cage..
86 Targa
91 964
13 6 SPD Cayenne
Old 12-16-2021, 07:00 AM
I replaced the front blower motor assemblies in my 964 and I was blown away (no pun intended) by the ****ty bearings they use in those units. My 964 only has 50k miles too.
'66 912 - Polo Red;
'74 911s - Silver Carrera RS clone
'77 911s - Peru red IROC Clone
'89 964 C4 - Guards red
Old 12-16-2021, 07:34 AM
