Missing components in relay
My safety belt warnig light stays ON all the time. My car is an 1985 european version without buzzer and wiring to the seat belt contact. It is a timing relay that is supposed to turn OFF the warning light after 2 or 3 minutes.
I opened the control relay and found out that some components might be missing. Or may be not. Not really sure. ![]() Can you please help me? Thanks ![]()
ummm, I pulled my relay out... old school I guess.
Is it supposed to have a coil or not? It is just a timer relay.
Miguel 911 carrera, year 1985 |
Miguel .put the key on and disconnect the battery ,this will reset the warning light.do this and report
.... if you like to have that relay ..i have plenty of them..but it is not important to have it there.. Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
also European models have this wire in there...
another test is to check continuity at the seat belt wiring under the seat (check both seats)... I think the limit switch is closed when there is no buckle in place. It could be that instead of the relay.
No missing components inside de relay, at least for your car. The PCB was probably designed for different car makes or models that needed additional components or features.
Faulty relay
Proporsche: In your collection, would you have one of these relays? 88 911 , 901 618 102
Robkammer16@gmail.com coupe |
hi Rob yes i do .....only not 87 but 1982 otherwise the same
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 04-09-2025 at 05:42 AM.. |
