Moses's Avatar
Angry I can't get WOT and I have PMS! HELP!
Yup, I have a Patrick motorsports 18 million dollar throttle cable installed. If I adjusted the nut to shorten the cable sufficiently to get wide open throttle, the idle would be at about 6000 RPM. (A bit high.) When I loosen it up until the motor idles normally, I don't get WOT.
What the heck?
Anybody know what to do next?
Old 05-15-2003, 09:15 PM
PRO Motorsports
Tyson Schmidt's Avatar
Moses, I believe that after all that bashing on the 915 trans you did in other posts, your trans has decided to "F" with you. I bet it's moving the throttle bell crank around just to piss you off.
I think you owe it an apology.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-15-2003, 09:50 PM
check the trottle coupling also. you might need to smash your tablets on this golden idol.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 05-16-2003, 05:22 AM
Moses, Moses, Moses....
So, if I understand correctly from your recent posts, when accelerating at WOT your eyeballs were smashed flat against the back of your skull. Your grip on the steering wheel was not to control the beast within but rather to simply keep you from breaking the seat-back and winding up slammed against the back window .
Now, two days later you're concerned that you're not quite getting all she's got??? YOU ARE POSESSED. YOU ARE MESHUGGENEH dear Moses.
OK...just having a little fun...actually I adjusted mine last night and took about 5/8" of free travel out of the throttle. One turn too far, and the idle would'nt settle out. One turn back and all is good. You might want to contact Patrick MS and see if they have ideas. Heck, for $18M (assume that's not Euro's) they ought to be happy to offer some tips. I know that most cables have several adjusting points that need to be "balanced" properly to optimize performance.
Just my uninformed 2 cents worth. Now, back to the morning's activities:
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 05-16-2003, 05:39 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
I have the million dollar cable...PM Harald, maybe he can guide you torward the light!
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 05-16-2003, 07:09 AM
Unregistered
sammyg2's Avatar
Payback from the SCWDP for dissing the SC engine
Old 05-16-2003, 07:28 AM
B58/732
BlueSkyJaunte's Avatar
Heh, heh, meshugeneh. I have't heard that since my grandmother called me a "vantz".
ΜΟΛΩΝ ΛΑΒΕ
Old 05-16-2003, 07:39 AM
Originally posted by Mike Feinstein
Moses, Moses, Moses.... ...just having a little fun...
Just as long as you're not wearing a slinky dress and black egyptian wig...just for fun
If the cable adjustment is correct there might be a smaller throttle cam you could use, or can you increase the stroke at the pedal end ?
Charlie Baer
'79 Euro 911SC (Guards Red)
'83 Quattro (Mars Red)
Old 05-16-2003, 08:40 AM
Check the adjustment at the peddle. Some have had to make adjustments to the stop at the back by cutting it off. I replaced my entire accel.peddle with the AJUSA version so I didn't have the problem of a stop limiting travel.
Old 05-16-2003, 08:42 AM
Does PMS stand for Patrick Motor Sports. If so, it will give me something to laugh at every month.
Old 05-16-2003, 08:54 AM
Moses's Avatar
Yes it does.
There was a classic post a while back when someone asked "How does this PMS part fit?" Thom Fitzpatrick replied " It just does , dammit!"
Old 05-16-2003, 09:15 AM
RETIRED
Joe Bob's Avatar
My go fast peddle had a plastic stop under it.....I pushed on it and had Ingo look at the throttle body....still had some room. Pulled the pedal, ground off the stop, no more problem.
Bench grinders, gotta love them.....
2012 ML350 3.0 Turbo Diesel
Old 05-16-2003, 11:18 AM
A man with a large selection of bigger hammers ?
Charlie Baer
Old 05-16-2003, 11:48 AM
