Overseas72
Idle issue '74 2.7 cis
1974 911 TARGA 2.7 CIS .
I've recently developed a idle issue. It has always taken a while to warm up to idle 20-30 min. Recently it has started to just cut off when i come to a stop . I can restart the engine and it will idle for a short time. The engine will serge up above normal idle then fall and cut off . I have changed the gas - same problem
07 Carrera S - Slate gray metallic 74 Targa - Salmon metallic |
Full Send Society
You need to do a thorough test of your CIS with pressure gauges, until then you’re just guessing.
Look at: Pelican thread “Cis for dummies” Jim’s basement workshop Once you have data, the problem can be identified and rectified.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
