Hatari's Avatar
Modified 3.2 ignition question
The 3.2 I posted a thread on a while back is in completion stages. The short list is:
9.8:1 JE pistons
Headwork by Memphis Motorwerks
Jerry Woods GE-60's, springs, retainers
46mm PMO's
Rods resized and balanced
Raceware rod bolts
Complete rebuilding inside case, new head studs
I finally elected to not go the twin-plug route thus the lower compression ratio, for a several reasons. I have a locked distributor from a 930 (and yes, we changed the drive gear on the crank to coincide). The engine should be completed and ready to start up in a couple more weeks.
I'm down to planning the ignition system...I'm thinking about an MSD 6AL box, but will need a timing computer to control the advance (hence locked distributor). MSD's website lists a couple of products that should do the job, but I'd appreciate any feedback from those that may have gone this route already.
Wayne, I see that you have the 6AL, can you get the MSD computers also?
Some progress photos are at my site:
http://brentwoodrocketscience.com/r2/r2.htm
Thanks,
Jack McAllister
Jack M.
72' 911T (73 RS replica-Kremer tribute)
1972 Yamaha DT2 (original owner)
Old 05-18-2003, 07:28 AM
CamB's Avatar
Cool!
Search for the user name "A Quiet Boom" and "timing" - Christian put some sort of MSD product with a customisable timing curve onto his 3.0 with Zeniths. He was very happy with it.
A few 3.0 questions
I have no idea which MSD product he is actually refering to!
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 05-18-2003, 02:09 PM
Hatari's Avatar
Cam,
Thanks, I'll look it up.
Jack
Jack M.
Old 05-18-2003, 02:12 PM
