Sick Of It! Time to update my SC Fusebox
For the third time this year my fuel pump fuse has loosened up and caused the engine to cut out or not start. Its annoying when it won't start and I have to pull out pliers and re-bend the fuse tab. Its dangerous when it cuts out while driving and I lose power.
Tonight I plan to stick in a quick hack with a modern fuse and a small splice for a weekend trip. Next week I want to begin a full box update. Here are the threads I'm planning to reference for info: Front Trunk Restoration Porn - lots of pics Fuse panel upgrade to ATO type ATO Fuse Panel...Last call before Christmas! My interpretation of the fuse panel upgrade Possible products http://www.ceautoelectricsupply.com/fuseholders.html http://store.chiefenterprises.com/Products/Multiple-Fuse-Relay-Holders/FP-ATO-S12 Useful images: ![]() ![]() Anyone else have thoughts or ideas? I plan to keep this thread updated with my progress and links to what I purchase. EDIT - More useful links: Fuse box layout help
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! Last edited by OsoMoore; 05-14-2014 at 08:39 AM.. |
Im throwing this out as a thought and someone here may have the answer as to why its not done this way.
Why not use circuit breakers (appropriately rated) instead of fuses. You will have to build some kind of a housing to keep them in but it will keep you from ever having to replace a fuse again. Just pull over, wait for it to cool off and switch it back on kind of like a house system. Other than that, it looks like the panel comes off in sections. Browse places like Digikey and see if you can find blocks of fuse holders. There are a ton of styles out there and im sure you can find one that will work. You could wire these in and build a box to hold them http://www.mouser.com/ProductDetail/Littelfuse/868-062-000/?qs=zHiv0nsVGmp8YI2jPiZzAg%3D%3D&gclid=COaQqbiRmr4CFfEDOgodZwQAiw or see what they have here http://www.digikey.com/product-search/en/circuit-protection/fuseholders/655422 Regards Dave
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) Last edited by Dave Colangelo; 05-07-2014 at 08:35 AM.. |
Definitely on my to-do list. Will be watching this one along with the others. Good luck!
ROW '78 911 Targa
You could just buy one that is made up and ready to install from Fred Cook.
I PMed him, this would be my first choice. I'm not sure if he's still selling them.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! |
ROW '78 911 Targa
He was last week in a PM he sent me.
Excellent. After a bunch of looking, I couldn't find any way to get all 21 fuses in a nice tight line without gaps like he does.
I might be able to rig my own cheaper, but the kit looks worth the money and would be good to have that knowledge base to tap.
Brew Master
I've been going back and forth with my brother about updating the fuse panel. How much is the modern panel?
This is where I chime in...........
Fred Cook here. Yes, still building fuse panels. At the moment, I can do them for 1969 thru 1989 911 and 930 cars. The 1974-89 panels come with 24 fuse positions instead of the stock 21 positions. This gives the owner some "spares" for future adds. I machine the bases from a piece of aluminum that is then covered with a type of adhesive lined heat shrink tubing. The fuse holders are added and then the appropriate jumpers needed to tie certain fuses together. The kits are available in two ways. First is the standard panel with the 24 fuse positions. This panel will fit under the stock fuse cover. The second option is a panel that is longer and is fitted with two additional relays for the headlights. Adding the headlight relay kit dramatically reduces the power that is drawn thru the headlight switch and the high low beam switch thus making them live longer. The kits include the fuse panel w/fuses, spare fuses, a fuse puller tool and instructions. Expect to spend about 8 hours or so doing the install. If you wish, instead of using regular fuses, you can use "smart" fuses that "glow when they blow" or even circuit breakers that will reset once a short is removed from the circuit. The smart fuses and circuit breakers are more expensive so you will have to buy those yourself. Costs.........the standard kit is $275 and the deluxe kit w/relays is $325.00. Expect it to take about a week from receipt of payment to shipping. Prices include shipping and insurance to any US zip code address. Out of the country is more. Hope this helps!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
My advice is to just change the bad fuse block with another stock one. Leave the rest alone. You'll be fine for another 30 years. Longer, if you do a little periodic maintanence...
JR |
Northern Motorhead
I installed one of Fred's fuse panels over last Winter,a little nerve wracking but well worth it in the end.Fred is very supportive if you need extra parts or installation help !
Cheers Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Cheap and easy ATO fuse block installation
This "Cheap and easy ATO fuse block installation " thread will save you most of time and money, especially as wires screw directly into new ATO block without needing to crimp several dozen quick-connects. ![]() So for 2 hours work and $30 this is a great improvement.
1982 911SC Wine Red Metallic OMG I love this car! Last edited by Algernon; 05-07-2014 at 07:47 PM.. |
El Duderino
I just got done installing Fred's fuse panel about 2 weekends ago. Cleaned up some nasty corroded wires and some hack jobs by some previous owner or mechanic. I wish I had done this sooner. I found a hairline crack in one of the fuse panels that was making a couple of the fuses loose. I never knew it until I took the old one out. I've been meaning to post some tips and lessons learned on doing this project. I will try to do that soon.
Picture is worth a 1000 words............
Just in case someone has not seen one of my fuse panel installations, here's a picture of the one in my SC, both with and without the cover.
I went ahead and ordered a 6 and a 15 fuse block. I'll see how it works out. For some reason, links to the 6 and 15 size blocks don't work, but you can see the 12 here, and get to the 6 and 15 from there:
FP-ATO-S12 ATO Blade Type Fuse Panel | Buy Online | Chief Enterprises Cost $37.75 including shipping. Spec info on these: http://www.geppowerproducts.com/product/cview/ato_blade_type_fuse_panels
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! Last edited by OsoMoore; 05-14-2014 at 09:30 AM.. |
This is an upgrade that I will be doing in the future.
I am going to watch this thread, as I have now had to deal with a fuse (in 3 different cases) being the fault - - not the fuse itself, but the connection between the fuse end and the holder. After seeing some of the (impressive) work by the fellow pelicaners; I can see that it will be an easy upgrade that will bring some slightly more modern technology to this car. I love the solution that Fred made, and looks to be a bit more of a "plug and play" solution ... I may go that route.
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. |
BW
I enthusiastically endorse Fred Cook's fuse panel. I read the instructions several times, including while looking at the old and new panels together. I called Fred a couple times before the install for clarification, he's terrific and patient. Gathered all the supplies and over the course of three days spent around eight hours doing a successful install.
BW 1989 Carrera--Rebel Racing Suspension, Patrick Motorsports LtWt Clutch Assembly, Enlarged TB, 964 Cams, SSI, Dansk Sport 2-in-1-out, SW Custom Chip, Turbo Tie Rods, Bump Steer Kit, H4s, Vintage Seats RS Replicas, RS Door Cards--and some other stuff |
The fuse blocks arrived. Hopefully I'll have time tonight to tag wires and be ready to do the swap by week's end.
When I did mine, I added 4 relays for headlights at same time. This saved 2 fuse positions, which I later used for oil cooler fan. Came in handy to have the extra fuse positions as fan takes large current and I did not want to add to an existing circuit. I ran a new feed from battery (through 25A fuse) for fan, and an 'ignition on' pickup to a 3A fuse to the fan controller. Hope this is helpful. If you need help, call three zero three 665-7336.
1982 911SC Wine Red Metallic OMG I love this car! |
Algernon
No problems or blown fuses since you installed the ATO fuse block ? |
