Fuchs Wheel Lock Key Help
I have these cylinder type wheel locks on my Fuchs, PO lost the key. I think these are Porsche wheel locks? The key should be a small silver/chrome key about the size of a standard Master Lock type key. Is anyone aware of a "master" for this type of lock or will I need to use a locksmith to pick these?
Old 02-11-2022, 02:04 PM
Bill Douglas's Avatar
If it's not in the glovebox or the toolkit I'd weld a nut on to remove it.
Old 02-11-2022, 02:59 PM
Thanks Bill, that end up being my best option.
Old 02-11-2022, 03:09 PM
I have some sockets that remove rounded bolts and nuts. See if that would work.
Old 02-11-2022, 04:38 PM
The outer sleeve spins freely until the inner cylinder is unlocked so no way to remove other than picking the lock or welding a nut to the center fixed cylinder.
Old 02-11-2022, 04:46 PM
Mine are made of aluminum. You can use a dent puller to take the outer cylinder off.
Old 02-11-2022, 05:12 PM
Functionista
manbridge 74's Avatar
I use a pointed tapered chisel that only takes one or two blows to crack them off in seconds, does no harm.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 02-12-2022, 12:25 PM
These may help you if you decide to get a locksmith. The key is 1 3/4" long.
Old 02-12-2022, 02:40 PM
