Lock nut for ball joint lock pin
The lock nut for the ball joint lock pin is a steel lock nut.
However, the picture on Pelican appears to be a conventional nylon lock nut.
Did it change over the years? I can call Pelican and ask as well.
https://www.pelicanparts.com/More_Info/90008400402.htm?pn=900-084-004-02-OEM&SVSVSI=792&DID=1845
Old 03-07-2022, 01:27 PM
prschmn's Avatar
I wouldn't fret about it. Once the pin is wedged in it really isn't doing much.
The nylock will be fine.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 03-08-2022, 02:04 PM
Thank you Mark! That was my gut too.
Old 03-09-2022, 09:45 AM
Senior Member
Superman's Avatar
My recollection of this nut is that it is all-steel and that it is shorter than the Nyloc nuts that hold the valve covers on. This is all from memory. But...I also think the Nyloc nut is also a steel nut, but with a plastic seal at the outer edge. the distal or lateral edge, if you will. So yeah, it probably doesn't make a big difference. Those wedge bolts are HARD to remove so I wouldn't expect one to fall out. Still, if I had a plain steel nut, I would use that instead.
Mocha 1978 911SC. "Coco"
Old 03-09-2022, 01:46 PM
I agree, removing the wedge bolt requires some commitment with a good hammer.
Old 03-09-2022, 01:52 PM
KTL KTL is offline
Schleprock
KTL's Avatar
And heat, and a drill.......
Kevin L
'86 Carrera "Larry"
Old 03-09-2022, 01:56 PM
Senior Member
Superman's Avatar
This. ^^^ The hammer strategy only shortens and widens the threaded stem.
Old 03-09-2022, 02:02 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Agreed. And a large, strong C-clamp with a receiving socket to press the pin out of the strut. Last thing we want to do is mush or bend the threaded end, making it even harder to move the pin out the hole
Kevin L
'86 Carrera "Larry"
Old 03-09-2022, 04:09 PM
Racer
winders's Avatar
When I knock the pin out with a brass hammer it usually goes flying someplace in my garage to be found later....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 03-09-2022, 04:22 PM
Thread a sacrificial nut onto the lock pin before you wail on it. Not only does it help prevent damage but it also keeps it from leaving the strut like a projectile.
Old 03-09-2022, 04:27 PM
