cruise control
I have a 1987 Carrera and I have a question I have not been able to get an answer to.
Where is the clutch switch located. I performed the trouble shooting per the Bentley manual and the clutch switch failed. I've asked several people where the switch is located. Please help. Thanks, Kevin
Old 08-18-2015, 04:04 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Right next to the gas pedal in the tunnel.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-18-2015, 04:09 PM
Brew Master
cabmandone's Avatar
I had to access mine from the tunnel just in front of the center console. Mine had bent or someone bent it and it wasn't making contact like it should. It's a very simple on off switch with an arm that contacts the clutch arm IIRC.
Old 08-18-2015, 04:32 PM
From my 1985 - here is the clutch switch after removal from the tunnel. It fits on the studs in the tunnel.
Old 08-18-2015, 07:59 PM
a better look at the switch lever arm from top view:
the front side of the assy is to the left.
Old 08-18-2015, 08:03 PM
Cruise control
Is in the same place as my car has the hydraulic clutch?
Old 08-19-2015, 12:16 AM
Cruise Control trouble chart has a huge ERROR on checking the clutch switch!!
The cruise control troubleshooting chart has a GLARING ERROR. The test that states
"Measure ohms from pin 3 to ground, depress clutch pedal, and the meter should read 10 ohms." is dead wrong! If you look at the wiring diagram below with the control unit unplugged, you will see there is NO WAY to get a 10ohm reading between ground and pin #3. I troubleshot my CC using the chart and could not get the 10ohms, so I traced the circuit.
The clutch switch contacts are "normally open" when the clutch is at rest. When you press the clutch, the switch contacts close and provide ground to the "Tempostat" relay on pin #85. This "picks" the relay and opens the relay contact path from pin #3 to the tempostat motor, deactivating CC.
The clutch switch is hooked to ground and ONLY goes to the relay coil. There is NO PATH to pin #3. Ergo you can't ever get 10ohms from ground to pin #3.
The absolute way to check if your clutch switch is operating is
1. pull the Tempostat (cruise control) relay
2. connect ohmmeter one lead to ground, the other to pin #85 of the tempostat relay plug. Should have no continuity, then depress the clutch and you should read 0 ohms (continuity) That is an ABSOLUTE TEST of the switch!
I don't know how many folks have been led down the "garden path" by using the trouble shooting chart in the Bentley, and thinking they have a bad or maladjusted clutch switch. But I'll bet it's quite a few!
I'm not the first guy to discover this error, see the quote below from a couple of years ago!
Originally Posted by dlshady View Post
Guys,
I know this has been discussed to death here but I've read through EVERY single thread that contains anything related to the cruise system and haven't found anything close to what I'm experiencing. Hopefully there's somebody out there that has been down this road before that can shed a little light on the problem for me.
Here's what I got: 83SC with a completely inoperative cruise system. I've been through this system from front to rear several times now, and this is what I come up with:
The schematic and the troubleshooting chart (Table C) in the Bentley manual don't jive. The second step in the chart shows that depressing the clutch pedal should result in a reading of 10 ohms between pin 3 and ground, but the schematic shows that depressing the clutch should merely ground the tempostat relay and interrupt the circuit on pin 3 between the cruise amp and the servo. In checking pin 3, I do NOT have 10 ohms to ground when pressing the clutch pedal, but I DO have an interruption in the circuit back to the servo. When checking resistance between pins 3 and 7 I have @15 ohms (this is the resistance of the servo and the wiring back to it), and it goes to open when the clutch is depressed. So by my logic, checking the circuit this way verifies that 1) the servo has the correct resistance, 2) the wiring back to it is indeed good, 3) the clutch switch and tempostat relay are working as they should.
So:
  • The clutch switch is good
  • The brake light switch applies @11.8 volts to pin 6 when the brakes are applied
I'm at the end of my rope with this car and I'm literally about ready to push it outside with the keys in it, hoping that some poor sucker will steal it.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 08-19-2015, 11:30 AM
Spiderman
Jesse16's Avatar
87 switch
I have an 87 and I believe he is correct that the switch is actuated off a pivot just right of the acc pedal. Remove the floorboard and you can likely see it. The pedals pivot from the floor with an actuator up to the clutch slave cylinder. Probably can be seen on the PET diagram also.
Actually, not sure if that switch is from the brake or clutch ?? You'll have to confirm for your car.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 08-19-2015, 02:09 PM
Kevin,
Your determination that you have a failing clutch switch may be completely wrong! The trouble shooting chart has a BAD error which can erroneously lead you to believe you have a bad or maladjusted clutch switch. Read my post #7 in this thread carefully for explanation and a fail proof way to check your clutch switch.
Old 08-19-2015, 03:10 PM
Cruise control
Thank you all for the advise, it's make sense! I hope to have it going this weekend. Kevin
Old 08-22-2015, 11:40 AM
It's an old thread but this helped me with my cruise control issues on my 1987 911.
Mine worked fine but one day I noticed if I depressed the clutch it didn't disengage the CC like it used to do. It's no big deal because I never really change gears with the CC engaged but I like everything to work on my car. I was dreading having to look in the tunnel and replace the clutch switch. Following the steps above I pulled the 4th relay from the front of the car and checked for continuity at #85 on the relay socket when the pedal was depressed. No problems... so clutch switch was fine... good news. With the relay pushed back in and ignition on there was no clicking sound when pushing clutch in and out so I changed the relay to a new one and it's all working as it should again. Cheap and easy fix.
Davin
'87 Carrera 3.2
'66 VW Camper
'59 VW Beetle
Old 03-16-2022, 09:27 PM
