Does anyone know where this piston is from?
Hello,
Years ago while collecting Porsche 'Stuff' i bought this piston. I just found it again after searching for another part and was wondering if anyone know what it may have been destined for before it was turned into art? It's approximately 93mm in diameter and looks to have a '5' hand engrave inside one of the skirts and a crudely drawn '0' inside the other shirt. Anyway just curious. Thanks Frank ![]() ![]() ![]()
76 911S Land Rover 110 Defender |
piston
For a non-hemi 4 valve head.
Porsche 959 .
Official porsche part , to be used as a desk ornament or ashtray or something ![]() Here’s mine . ![]() |
New-ish 911SC Targa Owner
Assuming it was originally a piston cast for actual use, what is with the little groove between the two compression ring grooves?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
So was it a promotions type thing sold at the dealerships as 'Art'???
I presume the groove was put in there to differentiate it from a QA approved part for install .
These where genuine 959 pistons ( carry over from 935 962 ) , and came from dealerships . Not sure if they where sold , or giving as gifts . If you Google it , you’ll find an interesting Sotheby’s auction result from a couple of years ago …. The latest version porsche has available is a 992 piston phone charger . https://www.porscheleeds.co.uk/about-us/2021/911-wireless-charging-piston/911%20wireless%20charging%20piston~leeds~~newsmode l~en https://www.porscheperth.co.uk/about-us/2021/911chargingpiston/porsche%20911%20wireless%20charging%20piston~perth ~~newsmodel~en Last edited by ian c2; 04-10-2022 at 07:38 PM.. Reason: Link added . |
It’s an “accumulator groove” . Used to gather oil between the two rings to promote lubrication.
Aaron. ![]() Burnham Performance https://www.instagram.com/burnhamperformance/ |
It's from the same era, and of a similar design. It was made in two pieces, then electron-beam welded together. This created a chamber into which oil was jetted. The oil inlet is seen in the lower photo, with an outlet on the other side. I suspect yours is similar? ![]() ![]()
Jon B. Vista, CA |
Cheers |
Thread Tools | |
Rate This Thread | |
