regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Symptoms were......
super you found the problem...so it is obvious the car did not drive in right?
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Carrera 3.0 engine problems.
Short update with main findings:
Wrong camshaft on the right bank: - generation 1 930 camshaft Wrong dizzie. - with ..001 last digits, should be ..006 Now new original camshafts and correct dizzie installed. Both timed to spec. Result: - engine running like new. Very reputable german Porsche engine shop rebuilt this engine 10 years ago and engine just set aside without staring it up until this spring. The list of wrong things found that the shop had done to it is shockingly long ! Case closed. Sent from my iPhone using Tapatalk Last edited by Classic 911; 12-17-2022 at 05:42 AM.. |
good for you but this is crazy..;-) "Very reputable german Porsche engine shop rebuilt this engine 10 years ago"
enjoy.... Ivan
New-ish 911SC Targa Owner
regarding the dizzie - Carrera 3.0 turns dizzie opposite direction from other 3.0 found in SC. What exactly was the one installed ending in 001 from? Just curious what difference is between that one and the correct one.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
According to Porsche the one with ..001 at the end is for the 2,7 engine. The one for the 3.0 Carrera enige has ..006 at the end. I have learned that there are differences between the mechanical components for the advancing curves. Last edited by Classic 911; 12-29-2022 at 06:22 AM.. |
