al lkosmal's Avatar
Originally Posted by Classic 911 View Post
Thank’s al
I found that # 1 is timed correct but #4 is not, the right camshaft is 180 degrees off.
I kinda thought so.......glad you found the problem.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 04-12-2022, 06:04 PM
regards,
al
Thank’s again al
Old 04-12-2022, 06:07 PM
Symptoms were......
Originally Posted by boyt911sc View Post
Check cam, ignition, and valve timing to confirm they are within specification.
Tony
Classic,
The symptoms of your problems were classic cam timing anomaly. Glad you identified the culprit. Good job.
Tony
Old 04-13-2022, 04:32 AM
Classic,
Tony
Thank’s Tony
Old 04-13-2022, 05:31 AM
proporsche's Avatar
super you found the problem...so it is obvious the car did not drive in right?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-13-2022, 12:30 PM
Ivan
Yes this car did not drive on it’s own
Thank’s Ivan
Old 04-14-2022, 05:21 AM
Carrera 3.0 engine problems.
Short update with main findings:
Wrong camshaft on the right bank:
- generation 1 930 camshaft
Wrong dizzie.
- with ..001 last digits, should be ..006
Now new original camshafts and correct dizzie installed. Both timed to spec.
Result: - engine running like new.
Very reputable german Porsche engine shop rebuilt this engine 10 years ago and engine just set aside without staring it up until this spring. The list of wrong things found that the shop had done to it is shockingly long !
Case closed.
Old 12-15-2022, 02:14 AM
proporsche's Avatar
good for you but this is crazy..;-) "Very reputable german Porsche engine shop rebuilt this engine 10 years ago"
enjoy....
Ivan
Old 12-15-2022, 02:28 AM
enjoy....
Ivan
Thank you Ivan
Old 12-17-2022, 05:39 AM
New-ish 911SC Targa Owner
pampadori's Avatar
regarding the dizzie - Carrera 3.0 turns dizzie opposite direction from other 3.0 found in SC. What exactly was the one installed ending in 001 from? Just curious what difference is between that one and the correct one.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 12-17-2022, 08:25 AM
According to Porsche the one with ..001 at the end is for the 2,7 engine. The one for the 3.0 Carrera enige has ..006 at the end.
I have learned that there are differences between the mechanical components for the advancing curves.
Old 12-29-2022, 06:19 AM
