Help me identify these wires
Removed the fresh air ventilation system from my 1971 911 T Targa to replace the blower motor and refurbish the windshield washer system. Once removed I found a solid white wire with a spade connector as well as a white wire with lime green stripes that had been wrapped in electrical tape.
Does anyone have any experience with these wires? I'd like to solve this mystery and make any repairs needed before reinstalling the ventilation system.
A quick glance at the wiring diagram for 1971 shows the following uses:
LIGHTING SYSTEM
Solid White Wire
High/Low beam steering wheel stalk switch > "Headlight flasher changeover relay" > Fuses 1 and 2 (bridged) > Headlights
White Wire with Lime Green Stripe
Light switch > "Headlight flasher changeover relay" > Speedometer (indicator light for Park Lamps)
Fog Lights: The white wire with lime green stripes was also used as part of the fog light wiring. My car does not have fog lights. Not sure if Porsche used 1 harness for all cars or of they were customized.
My high/low beams work fine and my park light indicator in the speedometer works too.
VENTILATION SYSTEM
Ventilation top lever: Fan Speed 1 > Fan motor (4 pole plug)
Solid White Wire
Ventilation top lever: Fan Speed 3 > Fan motor (4 pole plug)
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 12-26-2024, 03:02 PM
ROW '78 911 Targa
timmy2's Avatar
White/green is for rear fog lamp.
White wire from 6 pin connector is for the Webasto heater system.
Ignore both.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-26-2024, 09:23 PM
Thank you Timmy2
Old 12-27-2024, 06:37 AM
