| Registered Join Date: Apr 2022
				Transmission problem
			Hello, I’m new to the forum, and new to the 911 hobby. I was driving my recently purchased ‘77 911S home from work last night, on the freeway, doing about 75 in 5th gear, I felt a slight vibration, and then the engine rev’d - like it popped out of gear, it didn’t, it was still in the 5th gear gate. I selected every other forward gear, and had no engagement. No weird noises, or vibration, it will not move forward, or reverse. Any advice on what may have happened? Thank you -Jim | ||
|  04-23-2022, 06:48 AM |
| gearhead Join Date: Nov 2007 Location: Loverland, CO
			Clutch?
				__________________ 1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 | ||
|  04-23-2022, 06:51 AM |
| Registered Join Date: Mar 2001 Location: Marysville Wa.
			Broken cv joint? Axle popped loose?
				__________________ https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 | ||
|  04-23-2022, 07:32 AM |
| cycling has-been Join Date: Sep 2004 Location: Jersey Shore
			Remove the screws securing the inspection cover on the rear floor between the seats. See if you notice any amiss - like a disconnected coupler?
				__________________ 73 911T MFI, 76 912E, 77 Turbo Carrera | ||
|  04-23-2022, 07:39 AM |
You are right John, it amazes me it didn't tear anything up. Thank you. -Jim    Last edited by 77S3.2; 04-23-2022 at 07:43 AM.. | ||
|  04-23-2022, 07:40 AM |
			Outers usually just sit there. Inners can do some damage. Use new bolts and schnorr washers. Check the length of the new bolts against the old ones, 45 or 50mm.  12 point heads are better than 6 point, they can be tightened more and don't tend to round out the internal hex.
				__________________ https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 04-23-2022 at 09:19 AM.. | ||
|  04-23-2022, 09:14 AM |
| Eng-o-neer Join Date: Dec 2011 Location: Los Angeles
			It seems like a hell of a coincidence that both sides would push the last bolts out at the same time... I'd get a set of new bolts and some Schnorr washers...You'll need them maybe 5mm longer to fit the pair of Schnorrs, and if you go to long they'll fowl on the gearbox. I got mine from Bolt Depot. I believe torque is 60 ft-lb. | ||
|  04-23-2022, 10:08 AM |
