Not Weber KN rain hats?
So I picked these up to use on some ITBs, but I have since traded that setup. I was going to use these on a recent acquisition of Zeniths, but realize the bottom plate is not correct. I was told they are for webers, but clearly they are not. What other triple carb uses this bolt pattern? Just curious before I drill my own.
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 04-29-2022, 05:36 PM
al lkosmal's Avatar
Pmo
RGruppe #669
http://www.x-faktory.com/
Old 04-29-2022, 05:48 PM
Thanks Al! In that case maybe I shouldn't drill new holes. Anybody want to swap?
Old 04-29-2022, 07:06 PM
VFR750's Avatar
Cut away the central portion as needed
What I mean by that is the original designs are tough to work with. Larger openings make it easier to get to the emulsion tubes on zenith’s.
Old 04-30-2022, 11:10 AM
