Cad plating is available all over the northeast and is much better than zinc. It's even available in batch processing. It is about twice the price though.
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Thickness for thickness, which is more corrosion resistant depends on the exact atmosphere -- cadmium is generally better for salty environments, and zinc is generally better for industrial environments. But a thicker layer of a zinc alloy will provide better corrosion resistance than cadmium in every case, and every effort should be made to use zinc or a zinc alloy and to get cadmium out of the environment. Good luck.
For yellow plating, I only do yellow cadmium. Clear is a mix of a custom zing chemistry or cadmium ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Tru6 Restoration & Design Last edited by Shaun @ Tru6; 05-01-2022 at 07:57 AM.. |
Hmmmm I see some of my parts in those pics! Absolutely thats my housing strap/ Looks better in person.
Shaun gets top marks for communication, honesty and packaging, as well as quality. I think plating is kinda easy for him. Give him some Cerakote stuff. Challenge him
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Try Electrofinishing in Kent.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Sean that looks like yellow chromate ( sodium dichromate) not yellow cadmium.
There are definitely a few items I don't trust for batch plating and will send to Shaun @ Tru6 for period-correct cadmium plating.
any suggestions for a place to Cad Plate in NO CA?
Lots of good info
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Shaun @Tru 6 did all my plating work. His work and attention to detail is outstanding. I wouldn’t use anyone else to do plating and restoration work. My spring plates and axles should arrive in the next few days from Shaun.
I’ll post some more pictures of his work :-) ![]() ![]() ![]() ![]() ![]()
I would love to be wrong, as I understand cad is more durable and I need some plating done. Shaun, can you confirm that it's true cad with the gold/rainbow look? |
So yes, the plater I use has proper cadmium plating with a chromate layer on top. If I have to strip a cadmium plated piece, most times because I wasn't happy with the color or there was a flaw in the plating, it will sit in the bath for sometimes 20 minutes before all of the cadmium has been stripped. Zinc is always 2-3 minutes from start to finish. Fun fact, everyone thinks 911 door handles were black anodized; anodizing typically applies to aluminum, magnesium, titanium, etc. I just got a call today to reanodize door handles actually. In fact door handles are die cast zinc and were originally plated with black zinc chromate. If you look at the back of a door handle in the recess, you can see the chromate rainbow effect which is part of the spec. For yellow, some times it's more green, or rose, and sometimes it's beautiful RGB tones across gold.
Tru6 Restoration & Design |
Both zinc and cadmium are silver or whitish silver in color. The clear chromate for cadmium has a different chemistry than for zinc so you can get some beautiful silvers with the right pre-plating processing.
356 ![]() Ferrari 275 GTS brakes and such
I never really thought of plating like this as an art, but after looking at those pics, it sure feels like Shaun is an artist....
Received some more restoration work from Shaun, that I assembled last night.
Excellent results! Great work! Just realized that I put a washer on the driver side eccentric toe bolt. Need to address it today. ![]() ![]()
Tim |
