86 Carrera Cabriolet
Marined's Avatar
911 3.2 What did I break?
I was changing the Decklid Shocks and snapped off the white plug with the brown wire. The wire has 698611-7 on it.
What is the name of the white plug and where on PP is a part to replace it?
Thank you,
Ed
Old 05-08-2022, 05:41 PM
Mike W
It's the engine temp sensor. It goes to the #3 cylinder head.
Mike W
1988 911 Coupe
1986 911 Coupe
1974 911 Coupe
Old 05-08-2022, 05:48 PM
wrxnofx's Avatar
Pretty sure that’s the cylinder head temperature sensor (as opposed to the speed and reference sensors). You will want to pull out the metal plate that holds the connectors together and disconnect the sensor from the harness. If you’re lucky you only broke the connector on the sensor side and not the harness side.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 05-08-2022, 05:49 PM
wrxnofx's Avatar
Part number is 930 606 915 00
Old 05-08-2022, 05:56 PM
Also looks like the hose part of your vac/venturi line is cracked, probably causing a vac leak (brass tube transition to rubber hose).
Old 05-08-2022, 06:53 PM
A short length of shrink tubing will fix the hose crack for cheap.
206 637 4071
Old 05-08-2022, 07:19 PM
Let us know if it idles better once the hose is sealed.
Sent from my SM-G988B using Tapatalk
Old 05-08-2022, 10:45 PM
Originally Posted by wrxnofx View Post
...If you’re lucky you only broke the connector on the sensor side and not the harness side.
You got that backwards. He is lucky IF he broke the engine harness side. That connector is a dime a dozen (in black) and he can swap the pins over without even crimping on new ones.
If he broke the connector on the sensor side, he would have to REPLACE the entire sensor and that can become something really big, especially if the sensor refuses to come out of the head.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-09-2022, 06:01 AM
Diss Member
Quicksilver's Avatar
Good catch!
Another good fix is to cut off the crimped collar, remove the rubber and then use two different sizes of hose: one to fit the small tube and a larger one to fit the larger. The larger hose will fit over the smaller and a simple hose clamp makes a conventional seal.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 05-09-2022, 03:10 PM
If you put a bit of hot glue on the cracked hose and shrink over it, you have a solid connection. In the electrical terminal you can temporarily plug it back in and zip tie until parts come in.
Old 05-10-2022, 08:01 AM
Chain fence eating turbo
Broke mine the other day, too!!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 05-10-2022, 08:40 AM
Diss Member
BTW - The connectors are called "Junior Power Timer Connectors". Make sure you get ones with the correct number of connections because that style of connector is available with different number of contacts.
Old 05-10-2022, 11:53 AM
