Flojo's Avatar
Need tow hook with 5/8-11 UNS thread ?
Hi,
I recently installed the G-Model front tow hook receiver (bumper bar replacement tube) and now am facing the "problem" that the inner thread is equipped with a US 5/8-11 thread that is not common in Germany.
My bad I didn't check that before.
Did you guys come up with options on hooks/loops that have the proper thread?
My search on the web does only reveal expensive options though I guess in the US there must be some regular out there in any trunk (Ford, Chevy, etc) ?
@Rennline: fyi btw, the riveted aluminium thread nuts are junk, the threads are badly cut and when tightening down they turn loose. I drilled them out and attached bumper with my own solution. Recommend you rather weld threads to the plate.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 05-23-2022, 03:14 AM
Slippery Slope Victim
NY65912's Avatar
I used this on my IROC project years ago. Painted it red, worked fine.
https://www.mcmaster.com/3014T919/
Good Luck
MikeČ
1985 M491
Old 05-23-2022, 03:38 AM
It's a 914 ...
stownsen914's Avatar
Aluminum rivnuts for a tow hook attachment? I agree, it's not the choice I'd make.
Old 05-23-2022, 03:44 AM
Flojo's Avatar
Made something up myself of scrap I had
7 cm bolt 5/8-11
an old tow strap
some shims
and a 3/4 inch sleeve
Will do the job in case of a (hopefully) rare need
Old 05-25-2022, 09:39 AM
proporsche's Avatar
nice work flojo ..i just wonder why?....I have never seen any 911 being towed by this hook., that is factory..unless you are stuck on a racetrack...;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-25-2022, 10:34 AM
Antonov's Avatar
2nd this, I use and eye bolt from McMaster.
Good Luck
(kg/lb)
Old 05-25-2022, 10:36 AM
Flojo's Avatar
Ivan
If your car is lowered and has the turbo lip it may ruin the valance when hooking up the car to the factory loops at the A-arm as the towing angle of the strap/rope is inconvenient.
Old 06-03-2022, 11:34 AM
