Stripping Undercoating a Little Bit Cleaner Method
This cheap HF chisel works extremely well to remove undercoating, followed by a razor blade. Doesn’t even cut into primer coat once you get the hang of it. Of course the wire knotted wheel has to be used in certain spots. This method cuts down on that Smokey haze and the rubber webs strewn everywhere if that’s an issue in your home garage.I did this pan in a couple hours with minimal mess. However doesn’t help your tennis elbow.
Nice, what are you going to finish it with?
I'm not picking my nose..I'm porting my upper intake manifold. |
DP, nice work,
John
82 911SC coupe |
A coat of rm epoxy primer followed by upol gravitex.
Thread Tools | |
Rate This Thread | |
