GT3 Muffler Mounting on a '75 with a 964 motor
I have a GT3 muffler and all its brackets to put into my Rat Rod. The motor is a 964 motor, and has the A/C bracket removed. Also it uses a 3.2 style rear engine mount. The car has B&B headers as well.
To mount the muffler to the engine can I use the GT3 brackets? I some how doubt it. Can I use a 3.2 muffler bracket? Do I need to fab my own up? Should I just not bother with a bracket? How have people done this?
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 01-05-2022, 07:48 AM
Crotchety Old Bastard
RarlyL8's Avatar
We've done a bunch of these, doing a couple right now. Bracket is mandatory. You can use the OE bracket if it is modified. Much simpler to make your own and strap it to the muffler body and bolt to bottom of engine console. You don't want this muffler moving around or vibrating.
Old 01-06-2022, 06:23 AM
Appreciate to advice. Thanks.
Old 01-06-2022, 09:29 AM
Tom '74 911's Avatar
I run a GT3 muffler w/Fabspeed headers on the 964 3.6L engine in my '74 911. If you run into issues, I'm happy to post some pics. I can't remember off the top of my head how it's mounted... been a while since I needed to know that, so it was purged from my brain/hard drive!
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 01-06-2022, 02:52 PM
Pictures
Pictures would be great.
Backdate Widebody Project
Old 01-06-2022, 04:59 PM
I saw that Dansk is selling a couple of GT3 muffler to air cooled car mounts now.
Old 01-06-2022, 05:15 PM
Steve W's Avatar
Quiet muffler that doesn't kill power, does one exist?
Old 01-06-2022, 10:02 PM
RarlyL8's Avatar
"Building" a bracket for this application is beyond simple and inexpensive. A length of aluminum bar stock with 2 holes drilled for the bottom engine console and 2 clamps. Hang the muffler off the OE 911 bracket and secure the clamps. That's it.
Old 01-07-2022, 12:45 PM
Northern Motorhead
wildcat077's Avatar
Tom
Hey Tom,
Please do post some pictures ...
I have a 95 3.6 with Fabspeed headers in my 89 and i find the drone to be quite painful between 2 and 3 thousand rpms ,maybe it's the Fabspeed RSR muffler , but i would like some feedback on the GT3 setup you have !
Thank you
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 01-07-2022, 01:39 PM
That looks good and simple. When hanging off the stock muffler bracket, how does the exhaust tip line up with the bottom of the bumper?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 01-08-2022, 09:32 AM
Got a link?
Always learning.
Old 01-08-2022, 09:34 AM
I think it was Bursch on Instagram not Dansk.
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 01-08-2022, 01:45 PM
Here’s my bracket using the stock gt3 straps
81 SC 3.8 Conversion
2017 Macan S
INSTAGRAM @tail_spinz
Old 01-08-2022, 07:09 PM
Yes it was Bursch, my bad. Nice looking brackets
Old 01-08-2022, 07:51 PM
Found it...
Always learning.
Old 01-08-2022, 10:57 PM
Originally Posted by mikedsilva View Post
Found it...
Since I have converted the car to a Carrera RS style engine mount I decided to order the Bursch part.
Old 01-10-2022, 07:41 AM
That Bursch mount looks nice. Finally had a chance to get to my car and take a few pics. I couldn't find any markings on the mount so I'm not sure if it's commercially available... Rothsport built this motor for me and sourced the muffler and mount. Hope this helps!
Old 01-15-2022, 04:23 PM
Knowing Jeff Gamroth & Co (Rothsport Racing) that looks to me like they built the mount. Good quality work. I hope to get mine mounted up this week and will report back. Have to also build the y-pipes to connect to my B&B headers, with vacuum valves for the bypass side of the muffler.
Old 01-16-2022, 05:41 AM
This is an interesting bit of hardware that I do not have as part of my set-up... yet. The GT3 muffler does drone some, but I guess I've found it not so intolerable that I've been able to find the motivation to deal with it... I'm interested to hear how it works when completed! If there was a bolt-on kit that existed, I'd have for sure installed it - but nothing like this is ever "bolt-on". : ) : )
Old 01-16-2022, 07:58 AM
I have a 991 GT3 muffler I would love to use with my 79' SC, I am wanting to get SSIs so I can retain heat. How doable is this? Technically, the muffler is at my buddies shop about 4 hours away, so the next time I see him, I'll grab it.
1979 911 SC Gran Prix White. Gone but not forgotten.
2016 GT4, current steed.
IG @hulley31
Old 01-16-2022, 08:02 AM
