Permanent live too my MSD
Can I take the permanent live to my MSD from “fuse box 3 in the engine bay” or will this put too much load on the fuse
Old 05-30-2022, 12:38 PM
Full Send Society
Totally fine.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 05-30-2022, 01:21 PM
Is going past the fuse correct or before
Old 05-30-2022, 01:33 PM
Full Send Society
I have mine before the fuse with an inline fuse to protect the MSD unit. If you put it after the fuse you may have to change the fuse to a higher amperage but that’s probably not advisable.
-Julian
Old 05-30-2022, 02:10 PM
I ran mine like that for years without issue, although many will tell you to run a line off the starter.
Rutager West
Old 05-30-2022, 04:57 PM
What I like to do for power in the engine bay , is run a 10ga from the starter battery cable to the engine bay. At that point I can run a relay for ignition hot or just constant hot . Fuse as needed .
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 05-31-2022, 07:03 AM
Why do you want it hot at all times? I ran mine through a relay thats switched on with ignition.
Old 05-31-2022, 09:08 AM
The MSD wants the primary + to be hot all the time , then the internal MSD switch activates with the key to make the system hot .
Old 05-31-2022, 09:12 AM
