| Registered Join Date: Dec 2009
				Permanent live too my MSD
			Can I take the permanent live to my MSD from “fuse box 3 in the engine bay” or will this put too much load on the fuse    | ||
|  05-30-2022, 11:38 AM |
| Full Send Society |
			Totally fine.
				__________________ -Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html | ||
|  05-30-2022, 12:21 PM |
			Is going past the fuse correct or before
|  05-30-2022, 12:33 PM |
| Full Send Society |
			I have mine before the fuse with an inline fuse to protect the MSD unit. If you put it after the fuse you may have to change the fuse to a higher amperage but that’s probably not advisable.
|  05-30-2022, 01:10 PM |
| Registered |
			I ran mine like that for years without issue, although many will tell you to run a line off the starter.
				__________________ Rutager West 1977 911S Targa Chocolate Brown | ||
|  05-30-2022, 03:57 PM |
| Registered |
			What I like to do for power in the engine bay , is run a 10ga from the starter battery cable to the engine bay. At that point I can run a relay for ignition hot or just constant hot . Fuse as needed . Ian
				__________________ Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains | ||
|  05-31-2022, 06:03 AM |
| Registered |
			Why do you want it hot at all times?  I ran mine through a relay thats switched on with ignition.
|  05-31-2022, 08:08 AM |
| Registered |
			The MSD wants the primary + to be hot all the time , then the internal MSD switch activates with the key to make the system hot .
|  05-31-2022, 08:12 AM |
