khamul02's Avatar
CIS part numbers / availability / rebuild?
I think these parts are NLA. I couldn't find their part numbers in the parts diagram. There are a couple of small plastic bits that I would really like to replace. That yellow piece circled on my car has completely fallen apart. And most of my hoses are pretty hard. I could try to re-plasticize them but would rather have new ones.
I know Joe Engineer had these lines rebuilt. Does anyone know who does this type of work? I have a hose crimper but there is one hose close to the pipe and I don't think there is enough room for my crimper to get that one.
image from: Joe-engineer's blog Porsche 911 cis reassembly
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 06-12-2022, 08:07 PM
khamul02's Avatar
bump
Tom Hutchinson
Old 06-15-2022, 11:19 AM
A standard vacuum joint for a car should fit to replace the plastic piece. I was able to use a hose clamp and new rubber line to replace some of my cracked rubber hoses.
That part is available used. Whaletail in Canada had about 80 of them when I was there last..
Old 06-15-2022, 11:49 AM
Try a hydraulic tractor repair shop.
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 06-15-2022, 01:04 PM
lake wales fla
The power brake hose nipple connector (the yellowish one) part # is 930 110 267 00 AFAIK is NLA. What I use is the later connector that has the cruise control vacuum nipple part # 321 611 813 and just cap the vacuum nipple off. One benefit to using this style is you can easily hook up a smoke machine to the vacuum port for intake leak testing. Hope this helps , Richard
Old 06-15-2022, 02:01 PM
khamul02's Avatar
I didn't even think about cruise control. I'm removing it so I wonder what I can delete here on the hoses.
Tom Hutchinson
Old 06-16-2022, 01:53 PM
khamul02's Avatar
A couple of other notes. The plastic y adapter is a Venturi Tube. It has a VW logo on it part number 035133753A which through my research seems to be correct. While that part number is NLA, the 035133753b is used on the 928, 924, 944 and are. Does anyone know if these parts function in the same way. My understanding about Venturi tubes is they just change operating pressure or in this case vacuum. I guess I could buy a used one and cut them open to verify if no one knows.
035133753A
035133753B
Tom Hutchinson
Old 06-17-2022, 10:19 PM
