Anybody running Recaro Pole position seats on sliders in a 911?
If so what sliders are you using? I have a 86 930, any help would be great. Wanting to use the side mount recaro mounts and a slider.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 06-23-2022 at 08:26 AM.. |
use Recaro or Sparco sidemounts and sliders
looks like this the aluminum versions are far easier to work w/ than the steel and either is easier to work w/ than the BK ![]() ![]() ![]() ![]()
So recaro sliders?
I had both on hand and choose to use the Recaros
Ive seen the steel side mount readily avail. Must the be for Pole Position seats only or any Recaro? Also could you point me in the direction to get the sliders? Model or or style #? Seems to be a bunch out there.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) |
I run Recaro rails with Sparco sidemounts:
![]() Earlier also with Recaro steel mounts: ![]() ![]() ![]() ![]() And yes, drilled (for those who know me...)
Roland 930 Turbo '81 Too many modifications to list |
I don't use sliders but just want to add that on my 86, with the Recaro aluminum side mounts, combined with Recaro Pole Position FIA, that you will need spacers to fill the gap between the mount to the sides of the seats. I used to use the Recaro steel washer type spacers before but do not like them as it allowed the seat to wiggle side to side too much, and I think it also concentrates too much stress load at the seat's bolt points. Instead, I fabricated spacers from black cutting board plastic (HDPE) which eliminates the wiggle and completely stiffens the seat mounting in addition to distributing the load over a larger area of the seat's surface. If you use the Recaro steel side mounts, they are bent with an offset to not require spacers. Also the Sparco aluminum side mounts are bent with an offset like the Recaro steel mounts, not require spacers and match to the Recaro seat bolt holes too, though the upper most mounting holes are maybe 0.5 to 0.75" lower than the Recaro aluminum's. Since I do not use sliders (for a 12 lb weight saving), I use the higher mount points.
Thanks everybody this helps allot. I have factory sliders, starting to think I should buy aftermarket sliders?
a.k.a. G-man
Factory works great.
An extra hole drilled in the brackets and Bob’s your uncle.
Сидеть, ложь, Переворачиваться |
Turning this 930 track monster back to a street car "project" ![]() ![]()
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 06-25-2022 at 06:44 AM.. |
a.k.a. G-man
I have Recaro SPA on recaro brackets mounted on factory sliders.
I drilled one hole in each bracket to make them fit, that’s all. Works great.
a.k.a. G-man
![]() I know, car’s dirty… ![]()
The 3mm spacers Steve W alludes to are necessary if the RS inner buckle mounts are used
3mm spacers ![]() slider bolt washer on left RS inner buckle mount on right, ![]() ![]() ![]() ![]() ![]() another issue will be the height and angle of the buckle, I use SPGs with higher bolsters that aggravate the issue, so I used rear receptacle through the side hole, w/ PP the stock one can usually be bent enough another alternative is Southbound Trimmers which have the buckle mount integrale to the side like the newer GT3s ![]() ![]()
I went with the Steele black side mounts so that we didn't have to use the spacers. These will be mounted on factory sliders. We're also running Simpson 5 point harness with the seats. I know we're paying a weight penalty but the owner is not concerned with it. Thanks to everyone that chimed in.
on the door side use eye pads in the original door sill position and bolt a pair of eye pads in the tunnel area ![]() This from Schroth show the way the harness belts have to run, the issue that we have run into w/ PP is that the seat shoulder harness holes are too low and small for taller drivers, to allow a straight fetch at an acceptable angle to the shoulder ![]() here you can see the shoulder mounts through the hole in the SPGs, you want the cross bar as close as possible to the shoulder w/ no contact to the seat
Thanks Bill
Technically sliders are not legal for many racing organizations with racing buckets. However if you're using the sliders from the factory manual seats, those are even less safe because they only lock one rail, leaving the other one to slide and present fore and aft shear loading on the side of the seat with the fixed slider, concentrating a lot of load on those two fiberglass bolt points, which for a seat that formerly had a recall by Recaro due to due to non FIA compliance for mount point failure, is not the best idea. Imagine what could happen in a crash which could present a high g-force to the seat, such as if the back of the car slammed into a wall. Better to use aftermarket Recaro sliders that lock both sliders.
Ok thanks guys. I have purchased the Steele Recaro mounts. Im supposed to get factory sliders Monday from a local Porsche parts guy. You can see my car here. I guess my question regarding the double locking sliders from Recaro is do they just mount onto the factory slider mounting pods that you can see here on the bare floor boards or do you need to fabricate something?
Or is the problem running harness with seats that move forward/backwards? ![]()
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 06-25-2022 at 03:32 PM.. |
a.k.a. G-man
But strong argument. Double locking would be better.
