993 Caliper/ Rotor Adapter is here.
Promised a while back that I would post pics when we were finished with these, well here they are. Thanx to Bert Beagle, We've got the adapters finished and I must say they look fantastic. Still got to figure out the brake line, not sure I like this layout, any ideas? BTW these are '95 993tt Calipers and rotors. Read further...
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche Last edited by DUK; 10-02-2006 at 03:08 PM.. |
MMM sexy. That sure is an interesting way the caliper bolts up the strut. Kind of an improvement in size over your old M's, eh?
-Tom '73 911T MFI - in process of being restored '73 911T MFI - bare bones '87 924S - Keep's the Porsche DNA in my system while the 911 is down. aka "Wolf boy" |
I'd make a hard line and bolt up to the flex line at the strut, like stock. While mine isn't as shiny as yours, here's a pic:
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Ed is right,...
![]() That prevents a long flex line from interfering with the swaybar arms when the wheels are turned. BTDT, and thats a real pisser when the SS line gets torn loose,............
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
What hubs are used? I just turned down an old 911 hub for testing, rumor is the proper hub is a 944. Are the adaptors commercially available?
John Brasfield 91 C2 78 SC For sale 76 3.6 68 Datsun 2000 Mr. Magoo, 02 330ci |
Tom- Yea these are much bigger and more noticeable. How's your project coming?
John- I'm using turned down 911 hubs, they seem to have enough material still so I'm not too worried. The adapters are available at Pro-systems braking 704-799-8100 ask for Ashley.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
Senior Member
Looks very nice!
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Looks good, I wouldn't run the brake like like that either.
You will need 993 or 965 calipers on 930 rotors in the back as well, unless Ashley can come up w/ an off the shelf Brembo w/ ~30/34 pistons that will accept a 309x28mm rotor. ps I edited the original post to get a better presentation
Thanx Bill, Yes were going with 993 rear calipers and 930 rotors. I'm really looking for a good way to do the front line, any ideas or pics? Thanx, Duke
On second look that caliper does not appear to be a 993 caliper. It looks to be a 993tt caliper. The rotor does look llike a 993 front rotor. If so the caliper is not a good fit for the rotor. True 993 front calipers will use the same adaptor.
Bill, I'm confused again. These calipers seem to be 993tt but the 993 c2 pad works in them. Are the tt calipers wider? What issues do you mean as far as fitment to rotor?
The tt pad is a few mm taller, and does not have the holes for a pad puller
In this pic far to near, 993tt front, 993tt rear(same as n/a 993 front), 993rear(same as 964 f/r and 930 f/r) ![]()
we'll have to look closer at this, the 993 c2 pads fit perfect and the tt pads don't seem to, as they are too tall. Could you measure a tt caliper pad area? maybe from the striker plate bend to the top of the pad area? Mine measures 65mm. Thanx again and sorry to be such a bother, Duke
You can differentiate between the 2 calipers by the raised knob above the lettering and on the outside edge of the pad box on the tt
993 ![]() 993tt, 993RS, aka Big Red ![]()
Duke,
Did you turn down the hubs so the rotors can slip over? Looks good! Doug
1971 RSR - interpretation |
And, have you been acid staining your garage floor??
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Porsche-pa
Looks really sweet Duke. Bill sets the bar high but I like what you're doing with those 993 rotors. Were they hard to find? I wonder if anyone has ever tested (stop distance) the difference between a stock Carrera alloy brake and the 993's? I would think it would be a substancial gain, eh?
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious), Also rans... '02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7, Donny |
Will Fuchs work with that setup?
