Jameel's Avatar
Lighten up my steering
I'm looking for ideas on how to lighten up the steering effort in my '83 SC.
Here's my baseline:
380mm steering wheel (stock diameter)
Complete suspension rebuild to stock 4 years ago.
Turbo tie rods
I completely rebuilt the steering rack and regreased using the same wheel bearing
grease I used in my front wheel bearings.
Don't have a bunch of weight in the trunk. Maybe 10-15 pounds of stuff like a small folding chair and some detail spray.
6" stock Fuchs up front
Lowered just a hair below Euro.
I have driven several 911's of this era, and mine is by far the heaviest. My friend has a stock '81 SC and it steers like an early longhood. I just can't figure out why. The cars are nearly identical.
What am I missing? Any tips? This is like the last piece to make my car exactly what makes me grin from ear to ear. Thanks brothers and sisters.
1983 SC Coupe Chiffon White
3.0 rebuilt by me
9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch.
Old 07-26-2022, 05:13 AM
Did you replace steering column bushing/ bearings?
Old 07-26-2022, 05:27 AM
Going back to the stock size front tires will help the most. The cars were designed for the smaller less performance tires of the 70s and 80s. Drive one that is box stock, and you will notice nice light steering.
Mine is pretty heavy in a parking lot. If I am rolling more than a few MPH no problem at all.
Old 07-26-2022, 05:28 AM
ahead of the curve
Jeff Burger's Avatar
1. do the wheels turn easily with the weight off them ?
2. how sticky are the tires? look at tire pressure and raise to a higher level.
3. check alignment - reduce castor to min. the more castor the more it wants to keep going straight.
19 Carrera T - MPS member
92 C2 SR coupe M491/ 3.8 look- manual
92 C2 SR coupe cobolt blue- manual
73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy
73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
Old 07-26-2022, 06:09 AM
reduce caster
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 07-26-2022, 04:29 PM
Bill Douglas's Avatar
Put 36psi of air in the front wheels and go for a drive. If the steering is still heavy you have problems If the steering feels quite good work your way back with psi until you find what you are happy with.
I lubricate the bearings in the steering column.
Old 07-26-2022, 04:43 PM
Jameel's Avatar
Yes I think so.
Old 07-26-2022, 05:50 PM
Jameel's Avatar
I'm running stock size. Pilot sport AS3+
Old 07-26-2022, 05:51 PM
Jameel's Avatar
Yeah same as other SCs I work on.
Pilot Sport AS3+ at stock 29psi
Alignment is good and as close to factory spec as adjustment allows.
Old 07-26-2022, 05:52 PM
Jameel's Avatar
Will definitely try this. How do you lubricate the bushings? Do I need to take the whole column apart?
Old 07-26-2022, 05:54 PM
Jameel's Avatar
Originally Posted by RSTarga View Post
reduce caster
I don't think it's caster because it's much heavier than other cars at parking lot speeds
Old 07-26-2022, 05:55 PM
Mine is a bit different to yours. It's a right hand drive and the smugglers box is smaller. But I can see a universal type joint in there where it sits in a bushing or bearing cover. I oil that. Strangely it makes quite a difference.
Old 07-26-2022, 07:11 PM
Send a message via AIM to fintstone
Sounds like a steering rack issue. Maybe this thread would give you some ideas.
Steering stiff after rack rebuild
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-26-2022, 07:17 PM
LJ851's Avatar
Tight upper strut bearings and or ball joints can cause a lot of friction in the steering.
Old 07-27-2022, 05:16 AM
Jameel's Avatar
I been thinking about this lately. Here's some pics of my rack rebuild. I'm wondering if anything stands out as off? I used Mobil NLG1 grease. I also have video where I tested the movement with a torque wrench and it measured at 6lb ft. So that's in spec. Seems like a lot of grease in there, but I figure it gets squished out....maybe I'm wrong.
3.0 rebuilt by me
Old 03-04-2023, 09:04 AM
Jameel's Avatar
Well I did Bill's recommendation just now. Went out and pumped up my fronts to 34 psi and WOW what a huge difference 5 psi makes. I mean like night and day. This feels more like the longhoods and other SC's I've driven. What a great feeling.
So next question, do I need to worry about less grip up front? I do push the car from time to time, but not anything approaching 10/10. I'm thinking 5 psi won't matter much?
Thanks Bill for the suggestion!
3.0 rebuilt by me
Old 03-04-2023, 09:21 AM
The 9 Store
Lower the psi until it gets heavy.
All used parts sold as is.
Old 03-04-2023, 12:55 PM
Just go to the gym
Old 03-04-2023, 02:04 PM
Evan Fullerton's Avatar
Castor, camber, and wheel offset have huge affects on steering weight.
6in Fuchs are a good start for lighter steering but if you have a lot of castor or very little camber, both of these will add steering weight. Castor is weight jacking the car when you turn the wheel. That’s why it has a self centering affect….. but too much of a good thing adds a lot of steering effort. More camber reduces the contact patch size when going straight and keeps the contact patch from being on the outer edge of the tire when cornering which increases your leverage over the contact patch making the steering feel lighter.
Old 03-05-2023, 10:47 AM
Been here a while
I had a universal joint in the smugglers box get stuff. Some heat and kroil got my steering feel back to normal.
looking for 1972 911t motor XR584, S/N 6121622
Old 03-05-2023, 12:43 PM
