IROC's Avatar
3.2 Swap - Engine Won't Start!
I am on the home stretch on swapping a 3.2 into my '76, and with nervous excitement turned the key for the first time last night. No joy. It cranks just fine and has good fuel pressure, but it doesn't appear to have any spark. The only thing I had a chance to check was power to the coil and verified 12V to the coil when the key is on.
Any obvious things to check? This is my first involvement with Motronics....
Thanks,
Mike
Old 05-28-2003, 05:00 AM
Irrationally exuberant
ChrisBennet's Avatar
Is the reference sensor distance gapped correctly (0.8mm)? I missed this once and had to have my car towed to my mechanic friend. A little embarrassing but he didn't tease me at least.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-28-2003, 05:48 AM
Rick Lee's Avatar
Fuel pump? DME relay? Harness connection all correct? Send a PM to Marcesq.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 05-28-2003, 05:52 AM
IROC's Avatar
I checked the sensor gap when I installed the flywheel and it appeared to be OK.
The fuel pump is fine. I actually found this out the hard way when one of my fuel lines wasn't tightened all the way on the fuel filter.
One thing I may have done - reading the ultimate source of 911 maintenance info (my Haynes manual) - is that I *may* have accidently hooked up the speed and reference sensor connectors incorrectly. I may have the speed sensor plug on the reference sensor connector and vice versa. None of the connectors on the harness were marked and I pretty much made educated guesses as to where they went. All of them are pretty intuitive except for these two... I'm going to re-check that this evening.
The DME really was good when it came out of the donor car a couple of months ago. That is something that has already crossed my mind, though.
Thanks for the comments. Any additional insights would be welcomed.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 05-28-2003, 06:11 AM
GFCC
Jeff's Avatar
Mike, Did you bypass the alarm? The DME won't let the car run if the alarm is armed/ active.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 05-28-2003, 07:29 AM
IROC's Avatar
Alarm? What's that? I wish it was something that simple. My car doesn't even have a steering wheel lock, let alone an alarm.
Mike
Old 05-28-2003, 08:16 AM
Mike,
Definitely reversing the speed and reference sensor will prevent your car for starting and it's really easy to do. Just swap them and crank it and you'll know immediately. Also check your ground wires from the manifold to the car.
Dan O
84' 3.2 Targa
Old 05-28-2003, 10:25 AM
Platinum Member
dad911's Avatar
I did it too. Swap speed & reference sensor connectors.
Old 05-28-2003, 10:28 AM
IROC's Avatar
Originally posted by Dan Owens
Mike,
Cool! I'm going to swap them as soon as I get home. The ground wires to the manifold are in good shape.
Thanks for all the help!
Mike
Old 05-28-2003, 12:20 PM
MMARSH's Avatar
That is my suggestion, I did that once. switched them and the car fired right up. Good luck.
Michael
Old 05-28-2003, 03:31 PM
IROC's Avatar
This was the problem. Once I swapped these two plugs, it coughed a couple of times and fired up!!!
Life is good again.
Thanks for all y'all's help!!
Mike
Mike
1976 Euro 911
Old 05-28-2003, 03:43 PM
