3.2 Swap - Engine Won't Start!
I am on the home stretch on swapping a 3.2 into my '76, and with nervous excitement turned the key for the first time last night. No joy. It cranks just fine and has good fuel pressure, but it doesn't appear to have any spark. The only thing I had a chance to check was power to the coil and verified 12V to the coil when the key is on.
Any obvious things to check? This is my first involvement with Motronics.... Thanks, Mike |
Irrationally exuberant
Is the reference sensor distance gapped correctly (0.8mm)? I missed this once and had to have my car towed to my mechanic friend. A little embarrassing but he didn't tease me at least.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Fuel pump? DME relay? Harness connection all correct? Send a PM to Marcesq.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
I checked the sensor gap when I installed the flywheel and it appeared to be OK.
The fuel pump is fine. I actually found this out the hard way when one of my fuel lines wasn't tightened all the way on the fuel filter. One thing I may have done - reading the ultimate source of 911 maintenance info (my Haynes manual) - is that I *may* have accidently hooked up the speed and reference sensor connectors incorrectly. I may have the speed sensor plug on the reference sensor connector and vice versa. None of the connectors on the harness were marked and I pretty much made educated guesses as to where they went. All of them are pretty intuitive except for these two... I'm going to re-check that this evening. The DME really was good when it came out of the donor car a couple of months ago. That is something that has already crossed my mind, though. Thanks for the comments. Any additional insights would be welcomed. Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
GFCC
Mike, Did you bypass the alarm? The DME won't let the car run if the alarm is armed/ active.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
I wish it was something that simple. My car doesn't even have a steering wheel lock, let alone an alarm.Mike |
Mike,
Definitely reversing the speed and reference sensor will prevent your car for starting and it's really easy to do. Just swap them and crank it and you'll know immediately. Also check your ground wires from the manifold to the car.
Dan O 84' 3.2 Targa |
Platinum Member
I did it too. Swap speed & reference sensor connectors.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Thanks for all the help! Mike |
That is my suggestion, I did that once. switched them and the car fired right up. Good luck.
Michael |
This was the problem. Once I swapped these two plugs, it coughed a couple of times and fired up!!!
Life is good again. Thanks for all y'all's help!! Mike
