jphillips-998's Avatar
Middle of Alternator Replace...two ?s
Okay, seems pretty straight forward, however.........
As I was getting in to the project I noticed a wire disconnected from this part. Could this have something to do w/the alt. not working? Anyone know what the part is? It is located below and right of the fan housing.
Second ? is that in the tech article, it does not seem to mention this alt. cover? Anyone else have this? Is it a simple unbolt and remove, well not simple b/c the nuts are inaccessible....
Jeff
'04 Cayenne S Hauler
'98 993 Cab
'74 Euro Carrera - SOLD
'91 944S2 Track Car
Old 05-28-2003, 09:58 AM
I think you're looking at the oil pressure and/or oil temp senders....not directly related to the alternator's function.
Maybe this helps?
http://www.pelicanparts.com/techarticles/911_volt_reg_replace/911_volt_reg_replace.htm
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-28-2003, 10:08 AM
Friend of Warren
Yep top one is oil pressure sending unit and smaller brass object is oil temp. sending unit.
Kurt V
Old 05-28-2003, 10:11 AM
Thank you Wil, heading back to the garage now....it is never as easy as it seems is it? Anything w/flexible, patience and small hands are a plus worries me.
Jeff
'98 993 Cab
'91 944S2 Track Car
Old 05-28-2003, 10:14 AM
Somewhere in the Midwest
MotoSook's Avatar
Jeff, I found that when iwas doing my alternator, it might be easier to get at the thing if you remover the heating air duct...
...I wanted to R&R the CIS, so I ended dropping the motor! E-mail me if you need pictures and long winded instructions.
Old 05-28-2003, 10:15 AM
I just got it out....not a bad as I thought. The new one is on the way, hopefully this will take care of my ignition problems.
Jeff
'98 993 Cab
'91 944S2 Track Car
Old 05-28-2003, 11:19 AM
