Charge light resistor
1981 sc getting Valeo alternator. Have studied factory service bulletin and am comfortable with the install. Question is, does the Valeo #432776 still require a resistor added to the charge light bulb? Host doesn't offer one or mention this modification in product info.
Thanks in advance. Philip |
I don't know about a resistor but there is a Diode
https://www.digikey.com/en/products/detail/onsemi/1N4006/976986
Rey....77 930 "the Mistress" Last edited by speednme1; 08-16-2022 at 03:28 PM.. |
What's the service bulletin number?
I just had a Valeo installed in my 1987. If it needs something else, I'd like to sort that out.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
ROW '78 911 Targa
You will be fine Frank as your ‘87 was an internal voltage regulator already.
For external VR models you place a 91 ohm (100 will work) 5 watt resistor across the charge lamp wires to add a load so the internal regulator will activate and charge the battery.
Roger that. Thanks!
Targa_PB_78_SC
I wonder if I should add the resistor anyway?
BareRearedRookie |
Find Spoke's LED Products: www.spokeworksled.com |
As it turned out, no resistor was needed because I was unable to locate a new Valeo alternator anywhere.
The problematic Paris Rhone alternator had been rebuilt 2 years ago but was intermittently overcharging. Two Porsche shops pointed to the voltage regulator as the problem but I had previously tried other regulators and the problem remained. After bending a few ears at a local PCA sponsored cars and coffee, I got a referral to a rebuild shop, Chelmsford Auto Electric in Tyngsboro, MA. Took alternator in this past Monday, picked it up and reinstalled on Wednesday. Put on over 250 miles and it performs perfectly. Just wanted to take a moment to highly recommend this shop to those of you that may need rebuilding services in the future. |
Note: Paris-Rhone and Valeo are the same alternators.
Dave Last edited by mysocal911; 08-26-2022 at 06:53 PM.. |
Dave - do you mean the Marchall is very reliable, or the external regulator which serves it? My '77 911 had an external regulator, and I am fairly sure it was of the coil and points variety. I think those are subject to the problems old distributor points of the era had - pitting and so on. Or had Porsche changed to solid state external VRs?
On my hot rod track car I am using an older alternator, and use a solid state external VR from a 914. Small, light, and works just fine. Might just be dumb luck that it matches what the alternator needs, though. |
Plus, the mechanical reg can always be repaired and adjusted to whatever voltage you want.
Dave Last edited by mysocal911; 08-27-2022 at 07:56 AM.. |
My mistake on the brand if my alternator, it is indeed an SEV Marshal. It is the unit originally fitted to the car at the factory as I have owned this targa since new.
Sorry for the mixup. |
this is what you are looking for
Lorne M.
83 SC |
Here is a link to an earlier discussion regarding the change from external to internal regulater type alternators.
https://forums.pelicanparts.com/porsche-911-technical-forum/989178-electrical-wizard-help-needed-alternator-light.html
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
